Two Sup720VSS modules when VSS is not enabled ? Is this possible ?
dumlutimuralp
Hi all,
Is it possible to use two SUP720VSS modules in the same chassis, when VSS feature is disabled on the chassis ?
I couldnt come across a clear statement about this in VSS Q&A ?
It says "only one supervisor per chassis is supported when VSS is enabled", but what is the case when VSS is disabled on the chassis ?
Thanks in advance.
Edison Ortiz
Yes, you can use multiple Sup720-10Gs in a 6500 Switch with VSS disabled.
__
Edison.
