10-03-2007 06:31 AM - edited 03-05-2019 06:50 PM
I have two T1's coming into a 2811 router. How do I set up the FastEthernet 0/0 to handle this traffic from both T1's?
Here is what I thought but not sure it is right.
interface FastEthernet0/0
description Connection to office
ip address 192.168.99.3 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex full
speed 100
no cdp enable
no mop enabled
standby track Serial0/0/0.501 20
standby 1 ip 192.168.99.1
standby 1 priority 105
standby 1 preempt delay minimum 120
standby 1 authentication MI1
standby track Serial0/1/0.701 20
standby 1 authentication MI2
interface FastEthernet0/1
description Connection to MI
no ip address
shutdown
duplex full
speed 100
10-03-2007 07:00 AM
I am not sure what you are trying to do. Are there multiple routers? if not forget HSRP.
If you have a routing protocol running (or static routes) the router will forward traffic coming in the LAN acdcording to the routing table.
Any traffic from the T1s for 192.168.99.0/24 will be forwarded to the LAN - I think you are just trying too hard!
Paul.
07-19-2010 09:35 AM
I figured it out thanks.
