Two VTP Domains
RakaNRpG00
Hello everyone,
I have two core switches connected to one distribution switch then this distribution switch connected to two accesses switches  as it shown on the figure. MY Question is can I user the distribution switch as a path for two vtp server ?
balaji.bandi
Two VTP Domains
YES/ NO ---- 2 VTP domains, or same VTP Domain ? depends on requirement, as per requirement i see one VTP domain is good i guess here to replicate all vlans., suggest to use v2
BB
Deepak Kumar
This is not a recommended solution but you can use the PATH switch in a VTP mode transport mode. But you cant update VLAN information on the PATH sw.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
Unfortunately, you cannot do this as the distribution switch will need to be assigned to a vtp domain for it to participate in forwarding vtp advertisements, it cannot be in two differing vtp domains
Kind Regards
Paul
