tx drops catalyst 2960
art.bokhan
Community Member
Hello.
I have strange tx drops on gi ports of cat 2960. All ports have small transfer rates. Errors look strange and inexplicable. What is the possible reason?
Switch Ports Model              SW Version            SW Image
*    1 50    WS-C2960S-48TS-S   12.2(58)SE            C2960S-UNIVERSALK9-M
sh int gi0/1 controller
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is dc7b.94b7.9c01 (bia dc7b.94b7.9c01)
  Description: trunk
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 4/255, rxload 6/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:16, output 00:00:00, output hang never
  Last clearing of "show interface" counters 06:52:13
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 2828
  Queueing strategy: fifo
  Output queue: 0/4096 (size/max)
  5 minute input rate 24862000 bits/sec, 8752 packets/sec
  5 minute output rate 18520000 bits/sec, 4672 packets/sec
     246908278 packets input, 65467325427 bytes, 0 no buffer
     Received 213948 broadcasts (117704 multicasts)
     0 watchdog, 117704 multicast, 0 pause input
     142702266 packets output, 84278358054 bytes, 0 underruns
     820 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
     Transmit GigabitEthernet0/1              Receive
   1498118500 Bytes                       2527123071 Bytes
    715192093 Unicast frames              1231007062 Unicast frames
       926287 Multicast frames               1073674 Multicast frames
         4262 Broadcast frames                904655 Broadcast frames
            0 Too old frames              2313965628 Unicast bytes
            0 Deferred frames               79012047 Multicast bytes
            0 MTU exceeded frames           82825789 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames             1075799 Minimum size frames
            0 8 collision frames           646043936 65 to 127 byte frames
            0 9 collision frames           310520183 128 to 255 byte frames
            0 10 collision frames           71221231 256 to 511 byte frames
            0 11 collision frames           53776772 512 to 1023 byte frames
            0 12 collision frames          150328405 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames              19065 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
      1048624 64 byte frames                       0 Valid frames, too small
    369803960 127 byte frames
    121338068 255 byte frames                      0 Too old frames
     51240107 511 byte frames                      0 Valid oversize frames
     27503328 1023 byte frames                     0 System FCS error frames
    145173196 1518 byte frames                     0 RxPortFifoFull drop frame
        15359 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
harsingh2
It seems like this interface is receiving lot of Broadcast traffic. Minimize periodic broadcast traffic like routing and Service Advertising Protocol (SAP) updates (if applicable) by using access lists or by other means.
Can you provide output of sh run int g0/1. Try turning off IP fast switching by using no ip route-cache interface configuartion command.
HTH,
Harpreet
Leo Laohoo
Sounds like the client-side can't process 1Gb traffic.
