01-15-2019 11:05 AM - edited 03-08-2019 05:02 PM
Cisco docs are a bit confusing on this. So if UDLD normal mode is used, does the port/link remain up even when a unidirectional link failure is detected?
Solved! Go to Solution.
01-15-2019 11:11 AM
UDLD can operate in two modes: normal and aggressive.
In normal mode, if the link state of the port was determined to be bi-directional and the UDLD information times out, no action is taken by UDLD. The port state for UDLD is marked as undetermined. The port behaves according to its STP state.
In aggressive mode, if the link state of the port is determined to be bi-directional and the UDLD information times out while the link on the port is still up, UDLD tries to re-establish the state of the port. If not successful, the port is put into the errdisable state.
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/10591-77.html
01-15-2019 11:11 AM
01-15-2019 11:28 AM
01-15-2019 11:44 AM
Balaji already posted the answer to your question. You can also set up alerts, so you get text, email or both (depending on the application capabilities). This way if there is something wrong with the link in normal mode, you know about it and can fix it before it breaks.
01-15-2019 11:36 AM
Hi @CiscoBrownBelt,
Adding to what is indicated by @balaji.bandi, the following paragraph gives more clarity to your query:
UDLD information can age out due to the high error rate on the port caused by some physical issue or duplex mismatch. Such packet drop does not mean that the link is unidirectional and UDLD in normal mode will not disable such link.
