UDLD problem, goes in err-dis when it should'nt
pd.politiet.no
I have a 3750 and 6509 connected with fiber. When i take no shut on the interface at the 3750 side, the port goes in err-disable. I have tried a new fiber, new SFP and also changed ports. But the problem is still there. Below is the config and som output.
When I remove the "udld port" from the interface on the 3750, the port becomes up and traffic flows as normal.
Why?
3750:
interface GigabitEthernet1/0/25
switchport trunk native vlan 998
switchport trunk allowed vlan 1-179,190-679,682-689,800-4094
switchport mode trunk
udld port
Interface Gi1/0/25
Port enable administrative configuration setting: Enabled
Port enable operational state: Enabled
Current bidirectional state: Unidirectional
Current operational state: Disabled port
Message interval: 7
Time out interval: 5
No neighbor cache information stored
Sep 4 17:08:58: %UDLD-6-UDLD_PORT_RESET: UDLD reset interface Gi1/0/25
Sep 4 17:08:58: %PM-4-ERR_RECOVER: Attempting to recover from udld err-disable state on Gi1/0/25
Sep 4 17:09:01: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/25, changed state to up
Sep 4 17:09:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/25, changed state to up
Sep 4 17:09:05: %UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Gi1/0/25, unidirectional link detected
Sep 4 17:09:05: %PM-4-ERR_DISABLE: udld error detected on Gi1/0/25, putting Gi1/0/25 in err-disable state
Sep 4 17:09:06: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/25, changed state to down
Sep 4 17:09:07: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/25, changed state to down
3750_sw#udld reset
1 ports shutdown by UDLD were reset.
3750_sw#sh udld gigabitEthernet 1/0/25
Interface Gi1/0/25
Current bidirectional state: Neighbor's echo is empty
Current operational state: Detection
Message interval: 7
Entry 1
Expiration time: 21
Device ID: 1
Current neighbor state: Neighbor's echo is empty
Device name: 015C738100
Port ID: Gi3/7
Neighbor echo empty
Message interval: 7
CDP Device name: 6509_sw
Interface Gi1/0/25
Message interval: 7
Entry 1
Expiration time: 21
Device ID: 1
Current neighbor state: Unknown
Port ID: Gi3/7
Neighbor echo empty
Message interval: 7
6500:
interface GigabitEthernet3/7
switchport
udld port
spanning-tree guard root
Interface Gi3/7
Current bidirectional state: Unknown
Current operational state: Link down
Message interval: 7
Br
Geir
pd.politiet.no
Problem solved. Native vlan 998 was not created at the 3750. When i did, the port resolved from err-disabled when I reset the udld.
3750 was in transparent mode.
Geir
Hello Geir,
nice to hear that you solved this issue.
You have been kind to provide the root cause.
This makes this a complete story.
Best Regards
Giuseppe
