UDP port allow
yogesh1
Dear All,
I have VOIP PABX connected on my cisco firewall interface GigabitEthernet0/1.71 & LAN on GigabitEthernet0/1.101
So now i need to allow IP 197.84.140.140 , 196.28.95.12 with ports UDP Port 5060   UDP Port 16384 - 32767 & rest of the IP traffic should be block for VOIP interface only.
Please suggest command for same.
Firewall Model ASA5525
Version Device Manager Version 7.8(2)
Interface details
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         197.XX.XX.XX   YES CONFIG up                    up
GigabitEthernet0/1         unassigned      YES unset  up                    up
GigabitEthernet0/1.71      172.XX.XX.XX  YES CONFIG up                    up
GigabitEthernet0/1.101     10.XX.XX.XX     YES CONFIG up                    up
GigabitEthernet0/2         unassigned      YES unset  down                  down
5 Replies 5
balaji.bandi
This is good example guide to start with :
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/82446-enable-voip-config.html
based on ASA version some syntax changes, but concept is same.
BB
Dear Balaji,
I am just checking with post but unable to understand can you please suggest on commands how to enable multiple udp ports for particular IP by ACL??
Can you post your full configuration to suggest.
BB
Dear Balaji,
I am just discussing this with my team & as PABX is connected of firewall interface fa0/3 so can we make one policy in to out , out to in bidirectional & call that policy in zone after that put that PABX interface in that zone.
Also can you please let me know is PABX allow ACL feature.?
Please find the scenario  below i need to make source & destination policy .
Subnet 172.18.x.x is internal  voip subnet
Traffic which i need to allow for destination IP  (Out side network IP)
197.84.140.140                 UDP Port 5060   UDP Port 16384 - 32767
196.28.95.12                     UDP Port 5060   UDP Port 16384 - 32767
I need to make policy which allow traffic between  197.84.140.140   , 196.28.95.12  & 172.18.x.x including udp ports UDP Port 5060   UDP Port 16384 - 32767 or i  can allow all to all ports for these subnet & call the PABX connected interface in to this policy
This is what my requirement can you please suggest me on this.
Since we have asked full configuration, you have not provided for us to review.
based on the information you have provided, we belive rest all in in place and you looking onlyACL
below example  help you, tweak as per the your requirement.
object-group service PBX_Ports
port-object range 16384 32767
port-object eq 5060
object network inside_network
subnet 172.18.x.x 255.255.x.x
object network outside_network
host 197.84.140.140
host 196.28.95.12
access-list outside_access_in extended permit object-group outside_network any object inside_network eq PBX_Ports
access-list inside_access_out extended permit object-group inside_network any object outside_network eq PBX_Ports
Apply the access-list respected interface.
BB
