UDP segment reassembly |NO seq num in UDP header|
sarahr202
Level 5
Level 5
Hi everybody
I hope you are doing fine.
A quick question for you guys
Let say we have two host:
A------B
A wants to transfer data to B using UDP
Assume A  has a UDP segment of 10000  bytes to send to B
A chops down these 10000 bytes into each 1000 bytes chunk and sends total 10 packets to B, each carrying 1000 bytes as IP pay load.
B will wait for all the 10 packets, once all received, B ( ip layer) reassembles them into a UDP segment of 10000 bytes and gives it to UDP layer for processing.
1) UDP header has no seq number , so how does B determine all these packets belong to  a particular UDP segment ?
2) How does B knows that it has received the last packet belonging to a particular UDP segment and it is time to reassemble this last packet and give the reassembled UDP segment to UDP layer?
Giuseppe Larosa
Hello Sarah,
IPv4 header provides in this case the fragmentation and reassembly services, UDP just uses it being the upper layer protocol
last fragment has the M more fragments not set in the IPv4 header
Hope to help
Giuseppe
Giuseppe Larosa
Hello Sarah,
Hope to help
Giuseppe
Thanks Giuseppe.
