03-03-2011 05:53 AM - edited 03-06-2019 03:52 PM
Hi there,
1. I have a SUP720 versioning problem for my two SUP720 engines in 6509 so the redundancy is in bellow state.
sw01#show redundancy
Configured Redundancy Mode = sso
Operating Redundancy Mode = rpr
sw01#show mod
5 2 Supervisor Engine 720 (Cold) WS-SUP720-3B SAL1201C1FK
6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1201C1M4 <------------active
5 0016.46f9.8928 to 0016.46f9.892b 5.6 8.5(2) 12.2(33)SXH Ok
6 0016.c848.2b18 to 0016.c848.2b1b 5.6 8.5(2) 12.2(18)SXF7 Ok <-----------active
sw01#show sup-bootflash:
-#- --length-- -----date/time------ path
1 33554432 Jan 06 2008 17:44:00 sea_log.dat
2 81764868 Mar 07 2008 17:04:18 s72033-ipservicesk9_wan-mz.122-18.SXF7.bin
sw01#show slavebo
ukbraspsw01#show slavebootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. unknown 154D5D43 850C0 25 20544 --- -- ---- --:--:-- ----- crashinfo-20080224-161537
2 .. unknown B2ACB36B 852C4 38 388 --- -- ---- --:--:-- ----- crashinfo_kernel_trace-20080224-161537
boot system flash sup-bootdisk:
2. I am trying to establish a session to slot 5 but unable to connect.
sw01#session slot 5 processor 0
3. I am planning to copy the IOS across the SUP720 in slot 6 to slot5 and then reset the standby SUP720 with "redundancy reload" command.
to achieve High availability mode SSO (sso already configured).
could you please advice?
03-10-2011 12:47 AM
Hi Sanjeev,
Which version did you want to upgrade to? Assuming you wanted to get to SXH IOS
1. Could you do a
#dir sup-bootdisk: <<--- displays active
#dir slavesup-bootdisk: <<--- displays standby
You should be able to copy images between the two
eg. #copy sup-bootdisk: slavesup-bootdisk:
IOS will prompt you for the image name etc
You can also do a verify to check if it's copied properly
#verify slavesup-bootdisk:[image name]
2. You can't session to a standby SUP via telnet. You can see things on the standby console but you can't access it.
You can #remote login standby
3. If you wanted to get to SXH, then after ensuring all the images and boot variables are OK, you would #red force-switchover
this will make SLOT5 active and SLOT6 would boot to the new image.
From memory, As you are in RPR mode, this could be up to a 30- 60 second interruption to traffic during the switchover
P.S Recommend that you'd have console access during the upgrade process just in case.
