Unable to connect UCS C220 to HP Procurve Switch
alexgrinberg
I have an issue to connect UCS C220 server to the HP Procurve Switch. Base on the customer who manage the switch the switch port set up as a basic access port.
We can not even ping the port.
Any sugestions? can someone post the requared configuration for the HP switch?
Thank you
Mark Malone
There near identical to a Cisco switch at layer 2 basic vlan config nothing irregular  , if you stick a laptop connected direct to it can you ping it just to make sure its not the UCS side ?
https://nsrc.org/workshops/2017/caren-cndo/references/Layer2_hp_ref_en.pdf
