unable to load ios on 2960-cg
doubeleive
upon boot I get this error
switch: boot
Loading "flash:/c2960c405ex-universalk9-mz.150-2.SE5/c2960c405ex-universalk9-mz.
150-2.SE5.bin"...flash:/c2960c405ex-universalk9-mz.150-2.SE5/c2960c405ex-univers
alk9-mz.150-2.SE5.bin: invalid argument
Error loading "flash:/c2960c405ex-universalk9-mz.150-2.SE5/c2960c405ex-universal
k9-mz.150-2.SE5.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
when i try to xmodem a new ios onto the switch it also errors out on me
switch: copy xmodem: flash:c2960c405-universalk9-mz.152-7.E6.bin
mifs[4]: 5 files, 1 directories
Begin the Xmodem or Xmodem-1K transfer now...
mifs[4]: Bytes
CCCCCCBB0flash:c2960c405-universalk9-mz.152-7.E6.bin: not a directory
I'm stuck
what do you get with:
switch: dir ?
I check the image name, c2960c405ex-universalk9-mz.150-2.SE5.bin, it is a valid file. It requires 128/64 DRAM/Flash, make sure your switch has that amount free.
6 Replies 6
marce1000
                  >...Error loading "flash:/c2960c405ex-universalk9-mz.150-2.SE5/c2960c405ex-universal
 - Check or verify correct location of  the bin file , possibly the path specified is wrong, then boot manually , i and provide correct path to image.
 M.
I can't seem to be able to view the flash dir, when I type dir flash: it won't show the files (say's unable) but there are 6 files in there.
 - Provide exact error for dir flash: command , and or try fsck flash:  (include double column at end of this command)
 M.
switch: dir ?
Leo Laohoo
Is there a USB port (Type A) present?
doubeleive
I put this thing down for a couple weeks while I went on vacation and just hooked it back up this morning and it booted up and worked fine, I was able to factory reset it and good to go. not sure what the heck kind of hiccup that was but it's working fine now, thanks for the replies. I appreciate it.
