11-11-2015 05:51 PM - edited 03-08-2019 02:40 AM
I have two ASR1002 with the same exact configuration. One is able to issue ICMP traffic just fine while the other cannot even ping its own assigned IP addresses. The only difference here is that one has an ESP installed while the other does not. Does the ASR need the ESP in order to perform its functions? I came across this (see below) which lead me to believe that it does but I want to double check.
The Cisco ASR 1000 Series embedded service processors:
11-11-2015 06:27 PM
As far as I know, router ASR 1000 comes with Route Processor by default. I might be wrong. Route processor has a Mgmt-intf VRF. If you set ip address on the managment interface, it goes into that VRF. Use sh run to find a VRF. Then,
Show ip route VRF Mgmt-intf[ if the name is the same]
ping vrf Mgmt-intf [ip]
Please check the link below.
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/asrswcfg/Management_Ethernet.html#pgfId-1059026
Masoud
11-11-2015 06:27 PM
Thanks for the quick reply. I thought of that but I should at least be able to ping its own IP address. The management interface will only be used for that purpose and i cannot use it for other purpose such as routing to other transit network.
11-11-2015 06:37 PM
You are able to ping it by using VRF in your ping command.
ping vrf Mgmt-intf [Its own IP]
When you ping without using VRF, your router is searching for that IP in the Global routing table while that interface is in the Mgmt-intf VRF.
Try this,
Connect that interface to a PC, then ping the IP of that interface from PC . You will get reply.
ping vrf Mgmt-intf [PC IP] (from router)
Masoud,
11-11-2015 06:46 PM
I don't have vrf Mgmt-intf enabled on either ASR.
ASR with ESP installed
GigabitEthernet0/0/0 10.2.253.9 YES NVRAM up up
GigabitEthernet0/0/1 10.1.95.249 YES NVRAM up up
GigabitEthernet0/0/2 unassigned YES NVRAM down down
GigabitEthernet0/0/3 192.168.92.2 YES NVRAM up up
GigabitEthernet0 unassigned YES NVRAM administratively down down
#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 6/6/7 ms
ASR without ESP:
GigabitEthernet0/0/0 10.2.253.11 YES NVRAM down down
GigabitEthernet0/0/1 10.1.95.248 YES manual up up
GigabitEthernet0/0/3 192.168.92.6 YES NVRAM down down
ping 8.8.8.8
Success rate is 0 percent (0/5)
#ping 10.1.95.248
Sending 5, 100-byte ICMP Echos to 10.1.95.248, timeout is 2 seconds:
11-11-2015 06:49 PM
Please share the output of show IP route.
11-11-2015 06:52 PM
S* 0.0.0.0/0 [1/0] via 10.1.95.254
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.1.95.0/24 is directly connected, GigabitEthernet0/0/1
L 10.1.95.248/32 is directly connected, GigabitEthernet0/0/1
11-11-2015 06:59 PM
Everything looks good to me. Try to set a new IP address and ping again. Seperate its cable and check the status of that interface to see it goes down or still is UP UP.
Lets wait to see others feedback.
