Unable to ping between 2 directly connected switches
marvin-thomas
I'm setting up a lab and I'm having problems with one of the vlans.  I've got 2 3550 switches connected via 2 trunk links(fastethernet0/1 & 0/11 on each switch).  There are vlan interfaces that are pingable between the 2 switches but the problem is with vlan 20.  Here ae the relevant parts of the config:
Switch 1
interface Vlan20
ip address 10.2.2.2 255.255.255.0
end
interface FastEthernet0/1
switchport mode trunk
channel-protocol lacp
end
interface FastEthernet0/11
end
3550_SWITCH#sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
2950SW           Fas 0/24          120              S I   WS-C2950- Fas 0/2
3550_SWITCH2     Fas 0/11          159             R S I  WS-C3550- Fas 0/11
3550_SWITCH2     Fas 0/1           158             R S I  WS-C3550- Fas 0/1
3550_SWITCH#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Fa0/1       on               802.1q         trunking      1
Fa0/11      on               802.1q         trunking      1
Fa0/24      on               802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/1       1-4094
Fa0/11      1-4094
Fa0/24      1-4094
Port        Vlans allowed and active in management domain
Fa0/1       1,10,20,200
Fa0/11      1,10,20,200
Fa0/24      1,10,20,200
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/1       1,10,20,200
Fa0/11      1
Fa0/24      1,10,20,200
Switch 2
interface Vlan20
ip address 10.2.2.1 255.255.255.0
end
end
end
3550_SWITCH2#sh cdp neighbors
2950SW           Fas 0/24          135           S I      WS-C2950- Fas 0/1
3550_SWITCH      Fas 0/11          148          R S I     WS-C3550- Fas 0/11
3550_SWITCH      Fas 0/1           143          R S I     WS-C3550- Fas 0/1
R4               Fas 0/23          171            R       1750      Fas 0
3550_SWITCH2#sh int trunk
Fa0/1       1-4094
Fa0/11      1-4094
Fa0/24      1-4094
Fa0/1       1,10,20,200
Fa0/11      1,10,20,200
Fa0/24      1,10,20,200
Fa0/1       10,20,200
Fa0/11      10,20,200
Fa0/24      1,10,20,200
The thing thats concerning me is that it looks like there are vlans being pruned on the trunk links between the switches.  I've tried to allow all vlans on each link but its not having any impact.  Any suggestions are appreciated.
12 Replies 12
cadet alain
on SW1 can you do a sh spann vlan 20
Regards.
Alain.
3550_SWITCH#sh span vlan 20
VLAN0020
  Spanning tree enabled protocol ieee
  Root ID    Priority    32788
             Address     000d.bce4.b200
             Cost        19
             Port        1 (FastEthernet0/1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32788  (priority 32768 sys-id-ext 20)
             Address     000f.8fb2.eb00
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Fa0/1               Root FWD 19        128.1    P2p
Fa0/11              Altn BLK 19        128.11   P2p
Fa0/24              Desg FWD 19        128.24   P2p
So you got your answer as there is no port-channel, spanning-tree must block a port  and it blocked f0/11 on this switch.
This is a normal behaviourthat doesn't affect connectivity between the 2 switches..
Regards.
Alain
That doesn't seem to be the problem.  Now there is a port channel:
3550_SWITCH#sh spanning-tree vlan 20
VLAN0020
             Cost        12
             Port        65 (Port-channel12)
             Aging Time  300 sec
Fa0/24              Desg FWD 100       128.24   P2p
Po12                Root FWD 12        128.65   P2p
Pings still fail:
3550_SWITCH#ping 10.2.2.1
Sending 5, 100-byte ICMP Echos to 10.2.2.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Can you do debug arp while pinging
Regards.
Alain.
Hi Marvin,
do some L1 troubeshooting.
Ie shut down fa0/ on both sides and see if you can ping; if not try to shut fa0/11 instead.
Also remove portchannel and lacp from ports and see if can ping.
During all the tests always check both mac and arp tables to see if IP is arped and correct mac address is learned on the ports.
Riccardo
Thanks Riccardo and Alain.  I tried your suggestions and I'm still not able to ping the other switches vlan 20 interface.  Something I should re iterate is that there are other vlan interfaces on the same switch that I can ping and they are going over the same trunk.  Its only vlan 20 that's the problem.  Vlans 10 and 200 aren't experiencing the same problem.
3550_SWITCH#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.2.2.2                -   000f.8fb2.eb00  ARPA   Vlan20
Internet  10.2.1.1                -   000f.8fb2.eb00  ARPA   Vlan10
Internet  10.2.2.1                9   000d.bce4.b200  ARPA   Vlan20
Internet  10.2.1.2                9   000d.bce4.b200  ARPA   Vlan10
Internet  192.168.0.112           0   0016.41e1.8382  ARPA   Vlan1
Internet  192.168.0.9           235   001a.6dbf.9f00  ARPA   Vlan1
Internet  192.168.0.19            -   000f.8fb2.eb00  ARPA   Vlan1
Internet  192.168.1.129           -   000f.8fb2.eb00  ARPA   Vlan200
Internet  192.168.1.130           9   000d.bce4.b200  ARPA   Vlan200
Internet  10.2.1.254              -   0000.0c07.ac0a  ARPA   Vlan10
The mac address for vlan 20 is the correct mac address.
Marvin
It is interesting that the ARP table has the MAC for the other switch interface, and that you say that it is the correct MAC. So my suggestion for the next step in troubleshooting this is to see if the MAC 000d.bce4.b200 is in the switch MAC address forwarding table and if so what interface is it associated with?
Rick
Rick
To me everything looks as I would expect:
3550_SWITCH#sh adjacency 10.2.2.1 detail
Protocol Interface                 Address
IP       Vlan20                    10.2.2.1(7)
                                   0 packets, 0 bytes
                                   epoch 0
                                   sourced in sev-epoch 0
                                   Encap length 14
                                   000DBCE4B200000F8FB2EB000800
                                   L2 destination address byte offset 0
                                   L2 destination address byte length 6
                                   Link-type after encap: ip
                                   ARP
3550_SWITCH#sh ip cef 10.2.2.1 detail
10.2.2.1/32, epoch 0, flags attached
  Adj source: IP adj out of Vlan20, addr 10.2.2.1 037B15A0
   Dependent covered prefix type adjfib cover 10.2.2.0/24
  attached to Vlan20
And I just tried a reload of both switches(for the second time)
Try creating vlan 20 (layer-2) on both switches and test again
"vlan 20"
name vlan-20-test"
If not, remove the ports from the portchannell and just use one port and test
I don't know.  Here's what I did.  Took the IP off vlan 20, and created vlan 40.  I assigned the IP's I was using on vlan 20 to vlan 40 and it works.  Vlan.dat file corrupt in some way? Would be interested to hear others thoughts.  Thanks again for the responses from everyone.
Marvin
Could you please confirm whether you have configured any access port into that vlan ? if you not, the vlan won't come up & unable to ping.
please confirm whether the interface is up in both switches.
I don't think so port channel issue as STP will block only one interface not both so it should work with one interface.
Vignesh
