Unable to Ping Outside from ASA
Vikrant Ambhore
i am new in asa configuration.
I have a problem with my configuration i can not ping any external ip from my inside network
can someone tel me witch commande i have to put in my asa 5505 to allowed all trafic from the inside to the out side
I am able to ping Modem from ASA, but unable to ping 8.8.8.8
Modem(192.168.10.1)-------
----->(192
.168.10.2)
ASA(10.34.
249.33)
Vikrant
2 Accepted Solutions
Reza Sharifi
In config mode, can you add this command and test again?
icmp permit any outside
Hello Vikrant,
I hope you are doing great,
Would you mind posting the show run of the first ASA?
Also can you provide the show logg of both units.
Luis Sandi
Reza Sharifi
Please Look attached Diagram, This is my True Scenario, I need Internet on ASA-2
Hello Vikrant,
Luis Sandi
Thanks Luis Sandi
It's Solved
