Unable to ping router interface using OSPF - CCNA Lab
Angelo ANELLO
Hi Guys,
     I am currently studying for my CCNA and am trying to configure routers to use OSPF.  I am having trouble pinging a particular interface from one router and the same happens vice versa.  I cannot ping int FA0/0 on Router 2 from int s0 on Router 4.  All other devices can ping each other across all interfaces. I have attached files of the network diagram and the config setup.
Can anyone see any issues with the config that would restrict this from completing successfully.  This is a training lab setup.
Your help is appreciated
smehrnia
Level 7
Level 7
did you remove eigrp form all your routers and reconfig with OSPF?
can you ping router 2 from router 3?
can you ping router 3 from router 4?
if yes, then there must be a simulator bug.
this config should work fine
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
smehrnia
Level 7
Level 7
Soroush.
Hope it Helps!
Soroush.
Hi,  thanks for the reply.
I have checked all of the running configs and there is no trace of any other protocol other than ospf.  i will put this down to a simulator bug.
Thanks again
