Unable to read flash on Cisco 3850 switch
jragona4573
Anyone ever experience an issue when trying to read flash on a 3850 switch stack?
I was copying files from one switch to another in a stack, the process was going smooth until I hit the 2nd to last switch and no longer was able to sh flash. The switch goes into a frozen state and need to re-login to access command line.
balaji.bandi
Are you sure you used correct command
copy flash:XXXX to flash-1 or 2 so on ?
If the device is frozen, not much any one can help, check any Logs ?
take downtime and reboot the stack, capture console output completly
flash has still issue, do fsck
BB
Leo Laohoo
What files are these?
