Understanding C887VA-W-E-K9
Yorick Poels
I'm trying to set-up a Cisco 800 series router (C887VA-W-E-K9 ) (see setup in attach). Connecting via the PPPoE over ATM works flawlessly (see settings in config). I get an IP, DNS and route via the settings (ppp ipcp dns request accept -  ppp ipcp route default - ppp ipcp address accept).
The only problem I have, is from my host machine, I can NOT browse the web.
What is weird to me, is that from the host machine behind the router I can ping & traceroute to IP-adresses (e.g. 8.8.8.8). The router can ping to the host machine's IP (handed out via DHCP). From the #sh ip nat tr command, I can see that NAT translations are right. When I look at the NAT access-list, all entries got through.
Is it correct to use the int vlan 1 as a router for the dhcp pool?
Thanks in advance for helping me out.
Config:
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
no service password-recovery
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone Paris 1 0
no ip source-route
ip cef
ip dhcp pool LAN
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
lease 8
ip dhcp pool vlan4
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
ip dhcp pool vlan5
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
no ip domain lookup
ip domain name ykh
no ipv6 cef
license boot module c800 level advipservices
archive
path flash:archived-config
maximum 3
write-memory
time-period 1440
memory reserve console 2048
controller VDSL 0
ip ssh authentication-retries 5
ip ssh source-interface Loopback0
ip ssh version 2
interface Loopback0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface ATM0
description ADSL2+ interface
no ip address
no atm ilmi-keepalive
pvc internet-vc 8/35
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface Ethernet0
no ip address
no fair-queue
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
ip address 192.168.45.1 255.255.255.0
interface Vlan1
ip nat inside
ip tcp adjust-mss 1412
interface Vlan4
description vlan4 wireless BSUP
ip address 192.168.4.1 255.255.255.0
interface Vlan5
description vlan5 wireless BSUV
ip address 192.168.5.1 255.255.255.0
interface Dialer1
description Scarlet ADSL2+ dial-in interface
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap /deleted/
ppp chap /deleted/
no cdp enable
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list nat_acl interface Dialer1 overload
ip access-list extended nat_acl
permit ip 192.168.1.0 0.0.0.255 any
permit ip any any
dialer-list 1 protocol ip permit
end
Had another thought, is DNS working?
Add / change
DNS-server 8.8.8.8 4.2.2.4
to your dhcp config
Try ping www.google.com
Does it work ?
Stuart Gall
Have you tried lowering the mtu on the dialer. Some pppoe can not take 1500?
Hi Stuart, thanks for the suggestion.
In my config I have set it only to 1452. This evening I will try, with lower settings.
On my PC, I have also tried to ping with different packet sizes (as mentioned on
http://www.dslreports.com/faq/5793), with the ping -l option. The maximal packet size I can send was 1464.
Add / change
to your dhcp config
Does it work ?
Hi Stuart,
thanks for the suggestion, adding this DNS to the DHCP pool config fixed my problem.
Just a another quick question. When adding the DNS-server to the DHCP pool, it only gets applied to that pool. And when adding the 'ip name-server' in the config, it is valid for the whole router?
And another question .
Maybe you saw the 'ppp ipcp dns request accept' command under the dialer interface. Shouldn't the router request a DNS via this command when establishing the PPPoE session? And import it into the DHCP settings of the LAN pool through the 'import all' command? I will also check this using the debugging, to see if a DNS is found during the PPP negotiation.
