Unidrectional client vlan problem with HIPT phone
Lazarus G
I have a fault where client pcs attached to HIPT phones (not cisco) cannot participate on the network if they are disconnected from the phone and then reconnected.
Workstations that are left in situ dont experience the problem, however laptops do: but not in every case....
Once the fault has been exhibited we have found that we can connect any device (workstation/laptop/printer) to the phone and the fault will remain until the phone is restarted (remotely by the telephony provider, physically by the user removing and reseating the network cable or by us shutting/no shutting the switchport or removing and reapplying ILP to the port).
The PC will have nic lights but will receive mesage "unidentified network detected". The PCs are locked down by GPO so users have limited ability to assist with remote troubleshooting.
I have seen the issue on c3560v2-48ps and c3570v2-48ps ipbasek9 12.2(53)SE
I can see the PC MAC address on the port (aswell as the phone), the client usually has a DHCP lease and can even have an arp entry on the core.
Captures (SPAN and from the affected PC) show the PC initially sending DHCP requests, failing over to an APIPA address and then sending DHCP Discovers onto the network. However no responses are seen from the server in the captures. The phone works fine in the voice vlan and can make and receive calls all ok. Its as if the client vlan is operating in a uni-directional manner. I have stripped the config on the switch interface off line by line and the fault will still be present with only;
switchport mode access
switchport access vlan x
switchport voice vlan y
speed 100
duplex full
I have tried changing the access vlan but the fault persists.
I have verified that the server does send DHCP ACKS and OFFERS back to the client in the correct vlan, DHCP SNOOPING debugs (we dont have IP DHCP SNOOPING enabled but I have enabled it for testing to gain more information) show that the switch knows that which vlan and egress interface the client PC is attached to and that it is forwarding the packet onwards. However they arent getting onto the wire between the phone and the switch. In fact I cant see any captured packets going towards the PC.
The interface counters dont show any output drops or errors, I cant seen any drops in mls qos statistics. The controller output doesnt show anything unusual. I can add port acls to affected interfaces to check for bootps and bootpc but they will only show the ingress packets.
Unless Im fundamentally misinterpreting the output (very possible!) Im at a complete loss to explain where, and why, this traffic is dissapearing.
I have no options to run captures in IOS on these devices. I cant see any commands to show fabric or check backplane. Im not sure where else to look. Next time I will clear all counters on the interface before I start work......
Can anyone assist?
SWITCH#sh mac- int f0/3
          Mac Address Table
Vlan    Mac Address       Type        Ports
CLIENT    XXXX.XXXX.XXXX  STATIC      Fa0/3
VOICE     yyyy.yyyy.yyyy  STATIC   Fa0/3
Total Mac Addresses for this criterion: 2
SWITCH#sh int f0/3
FastEthernet0/3 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is f025.72b0.1e85 (bia f025.72b0.1e85)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:01:31, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 3000 bits/sec, 4 packets/sec
     24182472 packets input, 5314908683 bytes, 0 no buffer
     Received 819072 broadcasts (729095 multicasts)
     0 watchdog, 729095 multicast, 0 pause input
     67606534 packets output, 12571462460 bytes, 0 underruns
     Transmit FastEthernet0/3                 Receive
   3984993305 Bytes                       1023196232 Bytes
     26979925 Unicast frames                23402864 Unicast frames
     26646033 Multicast frames                729128 Multicast frames
     14021788 Broadcast frames                 90007 Broadcast frames
            0 Too old frames               913015998 Unicast bytes
            0 Deferred frames               70381604 Multicast bytes
            0 MTU exceeded frames           10113214 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames             2986936 Minimum size frames
            0 8 collision frames             8352962 65 to 127 byte frames
            0 9 collision frames             7756773 128 to 255 byte frames
            0 10 collision frames            3663553 256 to 511 byte frames
            0 11 collision frames             385172 512 to 1023 byte frames
            0 12 collision frames            1076603 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
      6732272 64 byte frames                       0 Valid frames, too small
     42863394 127 byte frames
     11262180 255 byte frames                      0 Too old frames
      2641393 511 byte frames                      0 Valid oversize frames
       395025 1023 byte frames                     0 System FCS error frames
      3753482 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: negotiate
Operational Trunking Encapsulation: native
Negotiation of Trunking: Off
Access Mode VLAN: X (Client)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: Y (Voice)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
SWITCH#sh int fastEthernet 0/3 summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface               IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* FastEthernet0/3          0     0    0     0 33000   50 37000   56    0
FastEthernet0/3 (All statistics are in packets)
  dscp: incoming
  0 -  4 :    16434978            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0         2338            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0       187967            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0      7215587            0          503            0
50 - 54 :           0            0            0            0         2487
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :    34190940            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0        23327            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0       176706            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0      7293648            0         4087            0
50 - 54 :           0            0            0            0          612
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :    17156425            0        37064       187967            0
  5 -  7 :     7215587            0            0
  cos: outgoing
  0 -  4 :    37308601            0        34038       176706            0
  5 -  7 :     7293648         4699        58351
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:           2           0     7295184
queue 1:           0        3203    23715920
queue 2:           0           0       34076
queue 3:           0           0    37404993
  output queues dropped:
queue 0:           0           0           0
queue 1:           0           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Mar  4 14:53:04: DHCP_SNOOPING: received new DHCP packet from input interface (FastEthernet0/3)
Mar  4 14:53:04: DHCP_SNOOPING: process new DHCP packet, message type: DHCPDISCOVER, input interface: Fa0/3, MAC da: ffff.ffff.ffff, MAC sa: XXXX.XXXX.XXXX, IP da: 255.255.255.255, IP sa: 0.0.0.0, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 0.0.0.0, DHCP siaddr: 0.0.0.0, DHCP giaddr: 0.0.0.0, DHCP chaddr: XXXX.XXXX.XXXX
Mar  4 14:53:04: DHCP_SNOOPING_SW: bridge packet get invalid mat entry: FFFF.FFFF.FFFF, packet is flooded to ingress VLAN: (X)
Mar  4 14:53:04: DHCP_SNOOPING_SW: bridge packet send packet to cpu port: VlanX.
Mar  4 14:53:04: DHCPSNOOP(hlfm_set_if_input): Setting if_input to Gi0/1 for pak.  Was VlX
Mar  4 14:53:04: DHCPSNOOP(hlfm_set_if_input): Setting if_input to VlX for pak.  Was Gi0/1
Mar  4 14:53:04: DHCP_SNOOPING: received new DHCP packet from input interface (GigabitEthernet0/1)
Mar  4 14:53:04: DHCP_SNOOPING: process new DHCP packet, message type: DHCPOFFER, input interface: Gi0/1, MAC da: ffff.ffff.ffff, MAC sa: ZZZZ.ZZZZ.ZZZZ, IP da: 255.255.255.255, IP sa: 10.n.n.1, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 10.n.n.48, DHCP siaddr: 10.n.n.50, DHCP giaddr: 10.n.n.1, DHCP chaddr: XXXX.XXXX.XXXX
Mar  4 14:53:04: DHCP_SNOOPING: process new DHCP packet, message type: DHCPOFFER, input interface: Gi0/1, MAC da: ffff.ffff.ffff, MAC sa: ZZZZ.ZZZZ.ZZZZ, IP da: 255.255.255.255, IP sa: 10.n.n.1, DHCP ciaddr: 0.0.0.0, DHCP yiaddr: 10.n.n.48, DHCP siaddr: 10.n.n.91, DHCP giaddr: 10.n.n.1, DHCP chaddr: XXXX.XXXX.XXXX
SWITCH#sh spanning-tree interface fastEthernet 0/3
Vlan                Role Sts Cost      Prio.Nbr Type
VLANX            Desg FWD 19        128.128  P2p Edge
VLANY           Desg FWD 19        128.128  P2p Edge
Lazarus G
Bump!
Looking for another example in the field
Plan is to get phone provider to statically assign ip on phone. clear interface and interface Ethernet controller counters, set port ACL to permit ingress bootps only. Turn off stp, Cdp and keeps Alives. Span the port.
I want only dhcp packets coming in from client. If the captures show no egress packets, but dhcp snooping debuts suggest packets are sent out correct interface, I want to see if the interface controller transmit counters increment in response to client dhcp packets.
Anyone know of a better way of getting this visibility?
Still not sure what to make if it if I do see this however....
