Unknown error copying IOS from USB to FLASH C3560CX
brianw360
Good day all,
I have a switch with no IOS, nothing in any directories. When trying to copy  c3560cx-universalk0-mz.152-7.E1.bin from the usb to flash it comes back with :unknown error. Should i run a format next?
After pressing return after copying the file name, i get this:
switch: copy usbflash0:3560cx-universal9k-mz.152-7.E1.bin flash:
usbflash0:3560cx-universal9k-mz.152-7.E1.bin: unknown error  (this gets amended to the line)
TIA
CPU rev: B
Image passed digital signature verification
Board rev: 2
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 00:6c:bc:5d:11:00
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    boot
switch: fsck flash:
Are you sure you want to fsck "flash:" (could take some time) (y/n)?y
mifs[9]: 1 files, 2 directories
mifs[9]: Total bytes     :  122185728
mifs[9]: Bytes used      :       2048
mifs[9]: Bytes available :  122183680
mifs[9]: mifs fsck took 0 seconds.
switch: format flash:
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
mifs[9]: 0 files, 1 directories
mifs[9]: Bytes used      :       1024
mifs[9]: Bytes available :  122184704
Filesystem "flash:" formatted
switch: dir
List of filesystems currently registered:
                  bs[1]: (read-only)
               flash[9]: (read-write)
              xmodem[10]: (read-only)
                null[11]: (read-write)
           usbflash0[13]: (read-write)
switch: dir flash:
Directory of flash:/
119321K bytes available (1K bytes used)
switch: dir usbflash0:
Directory of usbflash0:/
    4  -rw-  22780928  <date>               c3560cx-universalk9-mz.152-7.E1.bin
480728K bytes available (22272K bytes used)
switch: copy usbflash0:c3560cx-universalk9-mz.152-7.E1.bin flash:
flash:: no such file or directory
switch:
9 Replies 9
Mark Elsen
          - Not all USB and or formatted file system types are recognized by Cisco switches ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
It recognizes the file..
 - Some things to verify and or try 1) Issue show logging on the switch after the copy attempt is tried, check if you can find additional info's 2) Verify the md5sum of the bin file (on the switch itself) 3) Try to copy it from the usb to an external repository with tftp or scp (e.g.)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Instead of copy from USB to Flash first try boot from USB see if that works ?  (make sure copy all the boot logs and post here ?)
switch: boot usbflash0:/c3560cx-universalk9-mz.152-7.E1.bin
once it boot,
check dir flash:
copy usbflash0: flash:
let us know the the outcome.
BB
system software:
flash_init
boot
switch: flash_init
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 826368
mifs[5]: Bytes available : 979968
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 0 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1024
mifs[6]: Bytes available : 3869696
mifs[6]: mifs fsck took 0 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 1 seconds.
-- MORE --
mifs[9]: mifs fsck took 5 seconds.
...done Initializing Flash.
switch: dir flash:
2 drwx 512 <date> info_file_dir
3 -rwx 0 <date> c3750_ucode_image.tar
119320K bytes available (2K bytes used)
switch: boot usbflash0:c3560cx-universalk9-mz.152-7.E1.bin
Unknown cmd: dirboot
Loading "usbflash0:c3560cx-universalk9-mz.152-7.E1.bin"...Verifying image usbflash0:c3560cx-universalk9-mz.152-7.E1.bin............................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "usbflash0:c3560cx-universalk9-mz.152-7.E1.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560CX Software (C3560CX-UNIVERSALK9-M), Version 15.2(7)E1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Sat 07-Dec-19 10:22 by prod_rel_team
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 826368
mifs[7]: Bytes available : 979968
mifs[7]: Initialization complete.
mifs[8]: 0 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1024
mifs[8]: Bytes available : 3869696
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 1 files, 2 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 2048
mifs[11]: Bytes available : 122183680
mifs[11]: mifs fsck took 0 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
ucode info file is already there
mifs[11]: Error writing sector 11 error 3
%Error opening flash:/c3750_ucode_image.tar (Invalid argument)
not able to proces the info file
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: PortASIC Macsec Loopback Tests : Begin
POST: PortASIC Macsec Loopback Tests : End, Status Passed
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560CX-12PC-S (APM86XXX) processor (revision G0) with 524288K bytes of memory.
Processor board ID FOC2013Z1NN
Last reset from power-on
1 Virtual Ethernet interface
16 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:6C:BC:5D:11:00
Motherboard assembly number : 73-16468-04
Power supply part number : 341-0675-02
Motherboard serial number : FOC20125FAR
Power supply serial number : LIT20020168
Model revision number : G0
Motherboard revision number : A0
Model number : WS-C3560CX-12PC-S
System serial number : FOC2013Z1NN
Top Assembly Part Number : 68-5361-02
Top Assembly Revision Number : D0
Version ID : V02
CLEI Code Number : CMM1L10DRA
Hardware Board Revision Number : 0x02
503280K bytes of USB Flash usbflash0 (Read/Write)
Switch Ports Model SW Version SW Image
* 1 16 WS-C3560CX-12PC-S 15.2(7)E1 C3560CX-UNIVERSALK9-M
% Crashinfo may not be recovered at flash:/crashinfo_ext/crashinfo_ext
% This file system device reports an error
Press RETURN to get started!
*Mar 1 00:00:06.448: Read env variable - LICENSE_BOOT_LEVEL = ipservices
*Jan 2 00:00:00.517: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3560cx Next reboot level = ipbase and License = No valid license found
Feb 13 15:06:27.340: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Feb 13 15:06:29.200: %USB
nv_done: unable to open "flash:/multiple-fs.new"FLASH-5-CHANGE: usbflash0 has been inserted!
Feb 13 15:06:32.338: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Feb 13 15:06:35.390: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_open/read / file = flash:/vlan.dat / code = 22 (Invalid argument) / bytes transfered = 0
-Traceback= 8FC318z 3319F58z 331A5C0z 32D1FF8z 4319634z 4315324z
Feb 13 15:06:56.585: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
Feb 13 15:06:56.770: %SYS-5-RESTART: System restarted --
--- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enable secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
Would you like to enter the initial configuration dialog? [yes/no]: n
Switch>
Feb 13 15:07:58.790: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
%Error opening flash:pnp-tech-time (Invalid argument)
Feb 13 15:08:01.625: %PARSER-3-URLOPENFAIL: cannot open file for redirection 'Invalid argument'
Feb 13 15:08:02.624: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)
Switch>en
Switch#copy usbflash0:c3560cx-universalk9-mz.152-7.E1.bin flash:
%Error parsing filename (Invalid argument)
Switch#dir flash:
%Error opening flash:/ (Invalid argument)
Switch#end
Translating "end"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
Switch#
Switch#dir usbflash0:
4 -rw- 22780928 Feb 10 2023 11:34:36 +00:00 c3560cx-universalk9-mz.152-7.E1.bin
515072000 bytes total (492265472 bytes free)
Switch#dir
Switch#dir?
dir
Switch#dir ?
/all List all files
/recursive List files recursively
all-filesystems List files on all filesystems
bs: Directory or file name
cns: Directory or file name
flash: Directory or file name
null: Directory or file name
nvram: Directory or file name
system: Directory or file name
tar: Directory or file name
tmpsys: Directory or file name
usbflash0: Directory or file name
xmodem: Directory or file name
ymodem: Directory or file name
| Output modifiers
<cr>
Switch#dir /all
Switch#dir flash:
Switch#copy usbflash0: flash:
Your switch model is 3650X and you have Image in the flash 3750 ?
switch: dir flash:
Once you boot from USBFLASH with image c3560cx-universalk9-mz.152-7.E1.bin
fsck flash: This checks the filesystem and recovers it
format flash: This reformats the flash
then copy the image from USB to Flash, also change the boot variable to the correct image and reload the device.
Note : still issue post complete boot log
BB
CPU rev: B
Board rev: 2
Testing DataBus...
USB EHCI 1.00
USB Console INIT
system software:
    flash_init
    boot
switch: fsck flash:
switch: dir
                  bs[1]: (read-only)
switch: dir flash:
switch:
Most appreciative for your assistance.  We rebooted the device after taking out the flash drive and got us back to the user exec prompt.  Many many thanks!!!
Leo Laohoo
Flash is dead.  RMA the switch while it is still possible.
