Unknown process - createPhysicalen PID 183
richie
Community Member
Hi, just trying to find out what this process is:
PID 183 - createPhysicalen . I can't seem to find any information on it and it is randomly taking up 15-20% of the CPU, which I think may be affecting some of the RTT on pings that I am running. Any information or guidance on what this is would be greatly appreciated.
Giuseppe Larosa
Hello Richie,
try to use the following troubleshooting document for Catalyst 3750
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/68461-high-cpu-utilization-cat3750.html?dtid=osscdc000283
Hope to help
Giuseppe
Hi Giuseppe,
There's no mention of it in that document unfortunately.
Many thanks
Richie
Joseph W. Doherty
Yes it's possible that such a process has priority over the process which deals with pings, but unless you're dealing with a bug Cisco likely considers such a process more important than accurate RTT measurements for "ordinary" ping processing. Remember ping RTT was never intended for highly accurate network performance measurement. (That said, if the devices support SLA pings, your RTT measurements will be much more accurate even if the device is "busy".)
