unrecognizable characters while taking console for 3945 Router
Sijo Mathew
getting unrecognised characters while taking the console. tried changing speed but no hope..
Mark Elsen
 - What operator/terminal infrastructure are you using ? Anyway use speed of 9600. If no go reboot the device and tape the space bar during the boot. Check if this helps.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce,
am using putty , tried rebooting the device by tapping space.. no hope..
the bellow image that i can see once the device is booted
use 9600 as baudrate. also check your console cable and usb converter if using. sometimes, converters giving this kind of issues. is same cable and converters working properly, this can be a OS corruption which you have to use RMA procedure.
regards,
Good luck
KB
