mpls xconnect between cisco and juniper not coming up
mustansirt
hi ...trying to get mpls l2 xconnect up between cisco and juniper router but unable to do so.
local interface: Gi0/0/0.100 up, line protocol up, Eth VLAN 100 up
  Interworking type is Ethernet
  Destination address: 2.2.2.2, VC ID: 100, VC status: down
    Last error: Local access circuit is not ready for label advertise
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 00:22:47, last status change time: 4d10h
    Last label FSM state change time: 00:02:03
  Signaling protocol: LDP, peer 2.2.2.2:0 up
    Targeted Hello: 1.1.1.1(LDP Id) -> 2.2.2.2, LDP is DOWN, no binding
    Graceful restart: not configured and not enabled
    Non stop routing: not configured and not enabled
    Status TLV support (local/remote)   : enabled/None (no remote binding
      LDP route watch                   : enabled
      Label/status state machine        : local ready, LruRnd
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last BFD peer monitor  status rcvd: No fault
      Last local AC  circuit status rcvd: No fault
      Last local AC  circuit status sent: DOWN(not-forwarding)
      Last local PW i/f circ status rcvd: No fault
      Last local LDP TLV     status sent: No fault
      Last remote LDP TLV    status rcvd: None (no remote binding)
      Last remote LDP ADJ    status rcvd: None (no remote binding)
    MPLS VC labels: local 16, remote unassigned
    Group ID: local 8, remote unknown
    MTU: local 9000, remote unknown
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  Dataplane:
    SSM segment/switch IDs: 0/0 (used), PWID: 2
  VC statistics:
    transit packet totals: receive 0, send 0
    transit byte totals:   receive 0, send 0
    transit packet drops:  receive 0, seq error 0, send 0
sh mpls ldp bindings
  lib entry: 1.1.1.1/32, rev 2
local binding:  label: imp-null
remote binding: lsr: 2.2.2.2:0, label: 299872
  lib entry: 2.2.2.2/32, rev 11
local binding:  label: 18
remote binding: lsr: 2.2.2.2:0, label: imp-null
  lib entry: 10.20.30.0/30, rev 6
  lib entry: 40.50.60.0/30, rev 8
5 Replies 5
Harold Ritter
Could you please provide the output for "show mpls ldp discovery" and "show mpls ldp nei" from the cisco side.
Hi harold,
Please find the requested o/p's
sh mpls ldp discovery
Local LDP Identifier:
    1.1.1.1:0
    Discovery Sources:
    Interfaces:
GigabitEthernet0/1.1510 (ldp): xmit/recv
    LDP Id: 2.2.2.2:0
GigabitEthernet0/1.1511 (ldp): xmit/recv
    LDP Id: 2.2.2.2:0
    Targeted Hellos:
1.1.1.1 -> 2.2.2.2 (ldp): active, xmit
sh mpls ldp neighbor
    Peer LDP Ident: 2.2.2.2:0; Local LDP Ident 1.1.1.1:0
TCP connection: 2.2.2.2.54811 - 1.1.1.1.646
State: Oper; Msgs sent/rcvd: 661/564; Downstream
Up time: 01:32:50
LDP discovery sources:
  GigabitEthernet0/1.1510, Src IP addr: 40.50.60.1
  GigabitEthernet0/1.1511, Src IP addr: 10.20.30.1
        Addresses bound to peer LDP Ident:
          10.20.30.1      40.50.60.1
Do you have an access-list on either side of the session? Would it be possible to provide the configuration from both sides?
Thanks Harold,
But the issue was resolved from Juniper end. They need to explicitly add loopback0 interface for mpls ldp to advertise label for Loopback IP.
Once they did it the xconnect came UP.
I'm glad you found the solution.
Thanks for posting in the Cisco Community
