Untagged
husamabobakr
Dears,
i have one question regarding native vlan.
i have two switch as below :
SW1
inter f0/1
swicht port mode trunk
switch port trunk allow vlan 5-20
switch port trunk native vlan 10
SW2
inter f0/1
switch port trunk native vlan 100
the queistion is how sw2 will handle the traffic coming from sw1.
per to my understanding the traffic will be drop due to mismatch on the native vlan.
3 Accepted Solutions
Jon Marshall
If STP is running (and it should be) then it will see a native vlan mismatch and will put the port into blocking mode which is really what you want it to do.
If STP is not running then you have in effect joined two vlans together which is not really what you want to do.
Jon
If CDP is enabled, it will complain too, but as Jon notes, it's possible to "join" to different VLANs.
Similar can be accomplished if you join to "access" ports defined in different VLANs.
Dan Lukes
VLAN10  packets are sent untagged by SW1. SW2 considers untagged packets to be VLAN100
With no CDP enabled, switch knows nothing about it. Even with CDP enabled, it's just warning. Packets are still processed according configuration. But STP may block them.
See also Native VLAN mismatch and CDP
6 Replies 6
Jon Marshall
Jon
Thanks Mr, Joseph W.
Thanks Mr, Jon Marshall
Dan Lukes
Thanks a lot Mr,Dan Lukes :)
