'up arrow key' doesnt work properly on hyper terminal.
ohalnet53
hi all,
when changing catalyst switch configuration from Hyper terminal of my PC, I can not use the up arrow key to recall the last command. when I hit the "up arrow key" , some strange characters appears on the command line and executes those without hitting enter!
up arrow key works fine on other computers' hyper terminal.
you all know how useful that key when u r working on CLI.
what can I do to make it work properly?
tx in advance for helping.
7 Replies 7
pkhatri
Level 11
Level 11
Do the following:
- open up File -> Properties in HyperTerminal
- click on the Settings tab
- change Emulation to VT100
That should do it.
Hope that helps - pls rate the post if it does.
Paresh
thank you Paresh
Did that work ?
Thanks.
Paresh
have a look at installing the ´latest´ version of Hyperterminal as well, you can download it at the link below. Latest is relative, since it dates from 2003...:)
HyperTerminal Private Edition version 6.3
http://www.hilgraeve.com/htpe/index.html
GP
Paresh unfortunately it didnt work.
I will follow GPs advice.
greetings
while you are at it, you might want to try TeraTerm as well, you can download it here:
http://www.ayera.com/teraterm/download.htm
GP
Is your PC running Win2000 ?
If so, you may be afflicted with this problem:
http://support.microsoft.com/default.aspx?scid=KB;en-us;q263077
Paresh
