update switch from SG220-50 to layer 3 model
maik.brenke
To be enable to define a specific IP for each PORT on my current switch (SG220-50) I want to update my hardware. But what are the best cisco products to replace the current switch???
The following options are required:
- 19" Rack
- ~50 ETH-Ports
- assign static IP to each DHCP Client on each Switch-PORT (Port 1 to 192.168.0.1, Port 2 to X.X.X.2, … u.s.w)
- same connections and specifications as the SG220-50 (to be backward compatible)
- define gateway
- costs nearby the SG220-50
Thanks.
maik.brenke
The answer to my question is as follwoing:
I ordered a SG300-52.
To assign a static IP on a DHCP client which is connected to a specific PORT, a DHCP server is needed for every PORT.
For example:
PORT 1: 192.168.178.1
PORT 2: 192.168.178.2
PORT 3: 192.168.178.3
...and so on.
I tryed the following:
- set the switch to L3 mode
- created a new VLAN
- added the PORT to the VLAN
- set up a DHCP server for that VLAN/PORT
But the problem is:
- a DHCP server for the PORT requires a IP RANGE with more that one IP, so that it is not possible to add a single IP to a singel PORT
- on the other side the DHCP server defined a not changeable default gateway on the DHCP client (but in my case I need a special default on each DHCP client)
Therefore, a switch is no option to configure my network.
Case closed.
