Upgradation of Cisco1751 - 16 MB to 32 MB
chopra
I have cisco 1751 with 16 MB, now I want to upgrade it 32 MB Flash to use it for SIP. Can someone tell me the Part Number or ways to upgrade it.
10 Replies 10
I want to upgrade FLASH Memory. But you have sent the infprmations for upgrading of DRAM upgradtion. Please send me information how to upgrade FLASH Memory.
Hi Chopra,
Check this out from second link which I posted in my previous post
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a0080099429.html#wp1079010
HTH, if yes please rate the post.
Ankur
Hi Ankbhasi,
This link says that it not applicable for Cisco 1751.
Brgds
Arun Chopra
Hi Arun,
AFAIK 1751 default flash size is 32MB and is not upgradable so just check your flash again confirming what is the flash memory which exist in your router.
Ankur
I am 100% sure that my Router`s Flash is 16 MB.
I think the earlier models of the 1751 have 16MB default flash memory, which is not upgradable. The 1750 has a mini flash card slot for an additional 16MB mini flash card, but the 1751 does not, unfortunately.
GNT
My Cisco1751 has 16 MB Flash.
Show Version command verfies it:
Cisco1751#show version
Cisco Internetwork Operating Syst
IOS (tm) C1700 Software (C1700-SV8Y7-M), Version 12.3(2)T9, RELEASE SOFTWARE (fc
3)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 28-Oct-04 17:05 by eaarmas
Image text-base: 0x80008120, data-base: 0x8161C744
ROM: System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-SV8Y7-M), Version 12.3(2)T9, RELEASE SOFTWARE (fc3)
Cisco1751 uptime is 1 week, 6 days, 14 hours, 5 minutes
System restarted at 18:59:39 PCTime Wed Sep 27 2006
System image file is "flash:c1700-sv8y7-mz.123-2.T9.bin"
cisco 1751 (MPC860P) processor (revision 0x501) with 53969K/11567K bytes of memo
ry.
Processor board ID JAD05250PXT (3197734062), with hardware revision 6534
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
2 Voice FXO interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Hi Chopra,
It is not upgradable. Cisco1751 with 16mb of flash can be known as Cisco1751-LOWMEM chassis. Cisco do not have part id of 16F or 32F for Cisco1700 series. So you would not be able to get a flash to upgrade it. Cisco1700 series have its flash soldered on the board and do not have any extra slot for Flash to be upgrade.
Below attached image shows the soldered flash onboard.
Hope I answer your question.
Hi ericnq1983
I have a question, there is a way to identify those "LOWMEM" routers without opening them or using the command line tool "sh ver"?
Thank you very much!
(Also sorry for my poor english)
