VTP Setup From Multiple Switches
sadik.bash
Level 3
Level 3
I am working on a project to implement VTP in an enterprise environment. We have close to 45 switches(accss, dist, and core switches). I was wondering if there a way that I can poll all switches to find out what their current VPT setup is(server, transparent, or client) rather that connecting to each switch. Is there a way to accomplish that?
Thanks in advance.
Best, ~sK
Reza Sharifi
If you have SolarWinds, you can use the configuration management tool to look at the config for each device without login to every switch.
Dennis Mink
Try SNMP:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.46
Please remember to rate useful posts, by clicking on the stars below.
