upgrade 6500 with ACE module
Michal Valach
Hello I would like to ask you if I want to upgrade supervisor module, and I have in chasi ACE module as well. Do I need to take special care to ACE? Can supervisor upgrade affect ACE?
Thx
Karthick Murugan
Hi Michal,
If the ACE module worked fine in the present code, upgrading the code of supervisor module should not impact the ACE module. However, care should be taken if you are migrating the chassis to VSS setup.
Please refer the below datasheet
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/hardware.html#wp4654756
If the ACE model is different from the link provided then check for the datasheet for the specific model and the minimum required code before upgrade.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Karthick Murugan
Hi Michal,
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thank you  very much!!!
