Upgrade IE2000U
Arnaud Moritz
I need help for find a solution to my problem after my upgrade.
I wanted to upgrade my IE2000U-4TS  to ie2000u-lanbasek9 mz.150-2.EK1.bin version to ie2000u-lanbasek9-mz.152-3.E3.bin , but I upgraded with the wrong IOS ie2000-universalk9-mz.52-3.E3.bin .
I changed the boot path and reload. Note I have left the old IOS in the flash.
Classic !  The switch boot in rommon mode.
sdflash: contains unexpected values in partition table or boot sector.
Device needs formatting before use!
Loading ""...: no such device
Error loading ""
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
But the switch not recognizes the flash.
 switch: dir flash:
Directory of flash:/
56573K bytes available (1K bytes used)
switch: dir sdflash:
unable to stat sdflash:/: unknown error
I upgrade my switch with the XMODEM (Yeah !) and i boot on my IOS. For information I have taken the OLD IOS (ie2000u-lanbasek9 mz.150-2.EK1.bin) because he is smaller. The switch finally start. But after each restart the same problem ... Flash completely empty since the rommon.
No change after formatting the card, modify the boot sector filesystem and formatting in rommon mode.... Same problem
switch: dir flash:
I took for comparison starting another IE2000U and the only difference is the boot driver .
************* IE2000U Not Working ****************
FPGA version 0.14 downloaded successfully
Using driver version 4 for media type 1
Base ethernet MAC Address: 00:f2:8b:69:d4:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes : 1806336
mifs[2]: Bytes used : 689664
mifs[2]: Bytes available : 1116672
mifs[2]: mifs fsck took 0 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 3870720
mifs[3]: Bytes used : 1024
mifs[3]: Bytes available : 3869696
mifs[3]: mifs fsck took 1 seconds.
mifs[4]: 0 files, 1 directories
mifs[4]: Total bytes : 258048
mifs[4]: Bytes used : 1024
mifs[4]: Bytes available : 257024
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 0 files, 1 directories
mifs[5]: Total bytes : 258048
mifs[5]: Bytes used : 1024
mifs[5]: Bytes available : 257024
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 0 files, 1 directories
mifs[6]: Total bytes : 57931776
mifs[6]: Bytes used : 1024
mifs[6]: Bytes available : 57930752
mifs[6]: mifs fsck took 0 seconds.
...done Initializing Flash.
done.
Error loading ""
image.
********* IE2000U Working *************
Using driver version 3 for media type 1
Using driver version 3 for media type 4
Base ethernet MAC Address: 00:f2:8b:69:ce:00
mifs[6]: mifs fsck took 2 seconds.
mifs[8]: 10 files, 3 directories
mifs[8]: Total bytes : 134086656
mifs[8]: Bytes used : 18255872
mifs[8]: Bytes available : 115830784
mifs[8]: mifs fsck took 33 seconds.
done.
Loading "flash:/ie2000u-lanbasek9-mz.150-2.EK1/ie2000u-lanbasek9-mz.150-2.EK1.bin****************
Can you help me ? :)
6 Replies 6
Arnaud Moritz
I find the root cause... My Cisco IE2000U use the IE2000 Bootloader !
ROM: Bootstrap program is IE2000U boot loader
BOOTLDR: IE2000 Boot Loader (IE2000-HBOOT-M) Version 15.2(3r)E, RELEASE SOFTWARE (fc1)
Hi Arnaud,
Can you tell me how you managed to upgrade the boot loader to the IE2000U version?
I have the same issue and unfortunately each time the switch boots it reports that a boot loader upgrade is not needed???
Any help appreciated :-)
Rex.
These might help you:
http://www1.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie2000/software/release/15-0_1_ey/command/reference/cr-ie2000/bootldr.pdf
After check my issue with the TAC, I return the devices in RMA :(.
If you use a IE2000 image for upgrade your IE2000U, the boot loader use the IE2000 variable and can't boot.
cpalomequeffxw
What was the resolution for this problem. I am having the same issues stating above after trying to update the IOS to a new version.
Error loading ""
image.
 switch: dir flash:
 When i issue the version command i see this
the_c-man
Did the same error . Still waiting on TAC answer...
