upgrade memory for C3560
Bassamkareem
what is the maximum upgradable limit available for C3560 memory?
Mark Yeates
Level 7
Level 7
Bassam,
I don't believe that memory (flash or dram) can be upgraded in these kinds of switches. These are fixed configuration switches, designed to operate at their current capability. I did look and did not see a part number for larger memory chips for the 3560. Unlike most routers and modular switches they are not upgradeable memory wise.
Mark
Thanks mark for your quck response so what i have to do when there is a problem in memory can change or not ?
If you are having memory problems you should contact TAC. I Highly doubt that memory modules in the switch are field replaceable.
Mark
