dhcp snooping
MZydorczyk2
Level 4
Level 4
I am trying to set up dhcp snooping and was just wondering if the commands below are what I should be using for COS and IOS. Also, how would I do a test to see if the switch disables the port if it detects a DHCP server? I was thinking I could use ICS on a windows computer but I dont know if that would work.
COS
Code:
set securtity acl ip dhcpsnoop permit dhcp-snooping
set security acl ip dhcpsnoop permit ip any any
commit security acl dhcpsnoop
set acl map dhcpsnoop 1
set dhcp-snooping information host-tracking enable
set port dhcp-snooping 1/1 trust enable
Step 1
Configure the port as port based.
set port security-acl (port) port-based
Step 2
Enable IP source guard.
set port dhcp-snooping (port) source-guard enable
Step 3
Enable DHCP snooping.
set security acl ip dhcpsnoop permit dhcp-snooping
Step 4
Allow the port to forward other traffic.
Step 5
Save the ACL configuration.
Step 6
Enable the ACL on the VLAN.
set security acl map dhcpsnoop 1
Step 7
Enable DHCP-snooping trust on a port.
set port dhcp-snooping (port) trust enable
IOS
Code:
conf t
ip dhcp snooping
ip dhcp snooping vlan 1
ip dhcp snooping information option
interface (mod/port)
ip dhcp snooping trust
ip verify source vlan dhcp-snooping port-security
5 Replies 5
bvsnarayana03
Level 10
Level 10
config looks ok for IOS.
try this command for output:
sh ip dhcp snooping binding
Are ACL's not needed for snooping to work?
Istvan_Rabai
Level 11
Level 11
Hi Matthew,
You can test if dhcp snooping works by connecting another switch or router configured as DHCP server to any untrusted port and making the hosts send dhcp discover messages.
Of course, you'd better test the dhcp snooping trusted ports as well to see these ports do not block rightful dhcp packets.
Cheers:
Istvan
So hook a switch to the switch with dhcp snooping and then hook a computer to that switch?
Hi Matthew,
On the port that is configured as "trusted" in dhcp snooping, the switch will allow dhcp packets from a dhcp server.
On all other ports, dhcp packets will be rejected and the port will be put in errdisable state if dhcp replies are detected.
So it doesn't matter, where your dhcp server is located: it may be another switch hooked to the switch directly or it may be several hops away.
But you need to enable the port as "trusted" where the dhcp reply packets from the trusted dhcp server are expected to come in.
Cheers:
Istvan
