First timer
billybong
Level 4
Level 4
I usally find find solutions to my problems on cisco.com but alas i can't find a fix for this one
i have a sup-7203bxl showing this error on startup
- RELIABILITY DRIVER: wrong signature on NVFLASH
any ideas what this means
thanks
ccbootcamp
Level 10
Level 10
Try using the SXF series of image. I've been told that will fix it.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
ccbootcamp
Level 10
Level 10
I can take some guesses:
Bad IOS on flash
Bad NVRAM (config is corrupted)
Bad flash CF
Bad DRAM on sup engine
Bad sup engine
Start from the top down. Try it in this order and see if one of the following fixes it:
1) Reformat the flash, and re-up a good IOS image.
2) Erase your config. reload. re-paste the config after reload
3) Replace the CF card
4) Try different DRAM
5) CALL TAC
-brad
www.ccbootcamp.com
wimccall
Community Member
Can you paste a sh ver for that sup/image?
ccbootcamp
Level 10
Level 10
-brad
www.ccbootcamp.com
aches63
Frequent Visitor
Frequent Visitor
Hi, did you ever get this resolved? I have a 6509-E that I get the same message on at reload time. Cisco had me replace the SUP720 but that didn't fix it. I also removed the compact flash card and did a reload. Still got the message.
