upgrade Nexus7010
broow
Hardware
  cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 4115740 kB of memory.
running version 5.2(1) at present.  would like to upgrade to a more stable version.  at present do not need any more options.  what would the best most stable upgrade version with minimum disruption to service?
thanks
With the procedure I provided, you can jump up to 6 directly.
Reza Sharifi
Since you only have one sup, there will be disruption during the reboot.
Download the OS you want, put it on a flash drive and put the flash drive in to the USB port of the sup. copy both the system and the kick start image from the USB into the flash, run the install all command. once done you need to reboot.
thanks for the reply Reza,
I do have 2 sups:
Mod  Ports  Module-Type                         Model              Status
1    48     1000 Mbps Optical Ethernet Module   N7K-M148GS-11      ok
2    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
3    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
5    0      Supervisor module-1X                N7K-SUP1           active *
6    0      Supervisor module-1X                N7K-SUP1           ha-standby
8    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
9    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
10   48     1000 Mbps Optical Ethernet Module   N7K-M148GS-11      ok
Just wondering if i needed to upgrade in phases or could i jump up to version 6 without any issues?
