upgrade on 4507R+E single sup
lamnguyen2010
hi,
i would like to know how to upgrade firmware on 4507 6L-E Sup. There is only 1 Sup on the switch. is there any special requirement to update the firmware when switch not running on redundancy mode?
Thank you for all for your input!
-core-1#show redundancy states
       my state = 13 -ACTIVE
     peer state = 1  -DISABLED
           Mode = Simplex
           Unit = Primary
        Unit ID = 3
Redundancy Mode (Operational) = Stateful Switchover
Redundancy Mode (Configured)  = Stateful Switchover
Redundancy State              = Non Redundant
    Manual Swact = disabled (system is simplex (no peer unit))
Communications = Down      Reason: Simplex mode
   client count = 56
          keep_alive TMR = 9000 milliseconds
        keep_alive count = 0
    keep_alive threshold = 18
           RF debug mask = 0x0
DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
PID: WS-X45-SUP6L-E    , VID: V05 DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP) with 2 10GE X2 ports"
Reza Sharifi
Since you don't have a redundant Sup ISSU in not an option.  You will need an outage windows to upgrade.  Load the new image into the flash, change your boot variable to reflect the new image, reboot the switch.
Good Luck
