Need some basic help configuring a CISCO892W-AGN-E-K9
fred.appelman
Community Member
My knowledge is very basic so please bear me with me.
I just bought a CISCO892W-AGN-E-K9. This device has two indepent wireless antenna's, an 8 port internal switch plus two WAN links, 1 Gigabit Ethernet and a fast ethernet port and finally a backup ISDN line. I am not going to use the ISDN.
I am trying to get start with some very basic activity which is enabling the Gigabit Ethernet (or the FE, I don't care). My plan was to either give it a static IP address or a DHCP address. A DHCP server is present.
The first issue is that the WAN ports don't seem to be accessible. If I connect either of the WAN ports and power up the device they don't seem to be enabled, sending out DHCP or the like etc.
So I changed strategy and connected one of the internal switch ports. That works. It apparently does an DHCP over the 8 port switch and it does get an IP and so I can use telnet to login to the device. I am missing some converter so I haven't been able to use the console port.
So when I log in into the device I do find the GE but I can't find the FE or the switch port.
cisco-ap#show interfaces summary
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface              IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* BVI1                     0     0    0     0  2000    2     0    0    0
  Dot11Radio0              0     0    0     0     0    0     0    0    0
  Dot11Radio1              0     0    0     0     0    0     0    0    0
* GigabitEthernet0         0     0    0     0  3000    3     0    0    0
So it seems that the GE interface is connected to the internal switch. Where are my wlan ports?
Any help is appreciated. Just to be sure I'll append the show interfaces output and the running config (which is the default config).
     Fred
If I ask for the a list of interfaces using the ? I get:
cisco-ap#show interfaces ?
  Async               Async interface
  BVI                 Bridge-Group Virtual Interface
  CDMA-Ix             CDMA Ix interface
  CTunnel             CTunnel interface
  Dialer              Dialer interface
  Dot11Radio          IEEE 802.11 WLAN
  GigabitEthernet     GigabitEthernet IEEE 802.3z
  Loopback            Loopback interface
  Multilink           Multilink-group interface
  Null                Null interface
  Tunnel              Tunnel interface
  Vif                 PGM Multicast Host interface
  Virtual-Dot11Radio  Virtual Dot11 Interface
  Virtual-PPP         Virtual PPP interface
  Virtual-Template    Virtual Template interface
  Virtual-TokenRing   Virtual TokenRing
  accounting          Show interface accounting
  counters            Show interface counters
  crb                 Show interface routing/bridging info
  dampening           Show interface dampening info
  description         Show interface description
  irb                 Show interface routing/bridging info
  mac-accounting      Show interface MAC accounting info
  mpls-exp            Show interface MPLS experimental accounting info
  precedence          Show interface precedence accounting info
  rate-limit          Show interface rate-limit info
  stats               Show interface packets & octets, in & out, by switching path
  summary             Show interface summary
  switching           Show interface switching
  |                   Output modifiers
  <cr>
The running config:
Current configuration : 2997 bytes
version 12.4
no service pad
hostname cisco-ap
logging rate-limit console 9
enable secret 5 $1$cKpt$CwBHMRNrOKECVze4A5o66.
no aaa new-model
dot11 syslog
username cisco privilege 15 secret 5 $1$SGEn$qSAJ1dmxlz/GhYKMLjG4T.
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
15 Replies 15
Reza Sharifi
I have never used this device before, but apparently the APs are embedded and don't have external interfaces.
Have a look at this config guide on how to configure them:
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/wlan.html
First of all thank you for your help. As I said in my introduction I am an absolute beginner, nevertheless I try to follow the guido you referenced.
I run into a couple of issues:
  • There is no wlan-ap0 interface. So I assume it has to be the Gigabit interface.
  • I assign an IP to that interface (Not pingable though)
  • Then while in config-if I cannot issue an interface command. It is not there.
I did notice I can create an interface named GigabitEthernet 0.1 if that helps.
If someone can spoonfeed me this, that would be highly appreciated.
   Fred
Can you post the output of
"sh version" and
"sh ip int brief"
cisco-ap#sh version
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 02:29 by prod_rel_team
ROM: Bootstrap program is AP801 boot loader
BOOTLDR: AP801 Boot Loader (AP801-BOOT-M) Version 12.4(23c)JX, RELEASE SOFTWARE (fc1)
cisco-ap uptime is 11 hours, 10 minutes
System image file is "flash:/ap801-k9w7-mx.124-25d.JA1/ap801-k9w7-mx.124-25d.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AP801AGN-E-K9        (PowerPC 8343) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FCZ1707C6Q0
PowerPC 8343 CPU at 400Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 2C:54:2D:B9:D2:4C
Part Number                          : 73-11027-11
PCA Assembly Number                  : 800-28808-11
PCA Revision Number                  : C0
PCB Serial Number                    : FOC17016CTP
Top Assembly Part Number             : 800-29577-05
Top Assembly Serial Number           : FCZ1707C6Q0
Top Revision Number                   : C0
Product/Model Number                 : AP801AGN-E-K9
Configuration register is 0xF
cisco-ap#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       10.0.83.99      YES DHCP   up                    up
Dot11Radio0                unassigned      YES NVRAM  administratively down down
Dot11Radio1                unassigned      YES NVRAM  administratively down down
GigabitEthernet0           10.10.10.10     YES manual up                    up
Hi Fred,
You may try to configure 892 initially through CCP which is GUI oriented and get it working and then move to CLI if you are not comfortable with it yet.
More about CCP:
http://www.cisco.com/en/US/products/ps9422/index.html
http://www.cisco.com/en/US/prod/collateral/routers/ps9422/data_sheet_c78_462210.html
HTH,
Alex
Unfortunately I can't find it through the GUI either. I started with the GUI and then decided to move the CLI.
I even tried to install Install Express Pro (If I remember the name correctly). Once I tried to unpack the tar file from flash I got an error that a filename could not be longer than 40 chars. So halfway through the unpack failed.
So, you do have a Gig interface and it is in up and up mode.  In your previous post, you said you could not access the Gig interface, if so, how did you configure the IP address than (10.10.10.10)?
Sorry for the confusion. I added the IP address manually as part of the experimenting.
ip address 10.10.10.10 255.255.255.0
no ip route-cache
bridge-group 1
The issue is that although it says it is up, it can not be reached. Not from the inside or the outside.
Just to add to my own reply. So I don't know if this the somehow the inside (LAN switch) or the outside (GE). I ping it from both sides just to be sure.
Ok, so what is connected to this Gig interface right now?
I am *assuming* that the Gig interface is the Wan interface. I have connected the WAN inteface will a small switch (Am SG200). On the switch the Gig interface is *NOT* up.
Is the SG200 port also Gig?
If yes, on the 892 Gig interface can you delete this command and see if the interface comes up
no bridge-group 1
then
sh ip int bri
Yes the SG200 is 10/100/1000. I inserted it for that reason.
I cannot remove the bridge group:
cisco-ap(config-if)#no bridge-group 1
%command not allowed, cannot remove bridge-group 1
Thank you for the help so far. It will have to wait until tomorrow for futher updates.
In the config there is a section:
interface BVI1
no ip route-cache
Does this mean that this logical interface takes the IP address from the GE interface? That IP (10.0.83.99) is on internal (LAN) side and not on the external (WAN) side. This is so confusing.
cisco-ap#sh ip in brief
So where are the interfaces for the WAN GE or WAN FE interface?
    Fred
