03-24-2022 02:49 AM
Dear community,
I want to upgrade my switch, and in the Cisco official site, I found two files, the Firmware .bin one and the MIB folder which contains lots of file on it.
From the readings I understood that MIB is the boot code. However, I am unsure how to upgrade the boot code as the MIB folder contains lots of file inside.
Can someone point me to a resource were both firmware and boot code are upgraded in Cisco SG350X.
Looking forward to hearing from you.
Best regards,
Laura
Solved! Go to Solution.
03-24-2022 03:33 AM
example always .bin file :
image_tesla_hybrid_2.5.8.15_release_cisco_signed.bin
https://www.youtube.com/watch?v=U3VSsSOWMzo
03-24-2022 03:33 AM
03-24-2022 04:20 AM
yes that is correct for the .bin file for the firmware. But not for the Boot code! The video shows .ros and .rfp files for boot code. However, the package I downloaded from the Cisco site, does not contain any kind of file with these extensions.
Thank you,
Laura
03-24-2022 05:49 AM
if the boot required to upgrade, if not required you can use .bin to upgrade.
