Upgrade VSS quad-sup
vin.marco
Good morning
I have to run an IOS upgrade on two 6509-E with 2 VS-SUP2T-10G in VSS.
The version of IOS at this time is 15.1 (2) SY4a and I have to upgrade to 15.2 (1) SY.
What procedure should I have?
I have to enable some kind of license?
Thank you
Leo Laohoo
No.
Copy the IOS file into the bootflash of the four supervisor cards.  If the config registry is 0x2102 then change the boot variable string to point to the NEW IOS first and then add a second boot variable string that points to the OLD IOS.
If the config registry is 0x2101 then make sure the new IOS is the first IOS from the list (top to bottom).
Reboot.
I still have the copy ios also on standby cards
Yes, this is good practice.
