Upgrade WS-C3650-24TD-S from IP Base to IP services licence.
Vitalii
Hello everyone! I'd like to know can I upgrade WS-C3650-24TD-S switch (IP Base licence) to IP Services licence for this one?
Reza Sharifi
Yes, you would need to purchase the license from your Cisco rep or a partner and than install it. The commands to install it is:
icense right-to-use activate ipservices all
license right-to-use activate ipservices all acceptEULA
5 Replies 5
Reza Sharifi
Does IP Base licence support static routing?
Yes, absolutely.
Appreciate your help.
Glad to help!
If you just need to add static IPs, you don't need IP Services license. The IP Based is just fine.  IP services license is for advanced features like VRF, multicast, BGP, etc..
