Upgraded 3650 slave by mistake
shower
I'm struggling to learn Cisco 3650 stacked switches and need help. I successfully upgraded a 3650 switch with version 16.12.12 software. Unfortunately, I started with the slave. All went well until I upgraded the master. Now I can't reach either switch or any device connected to the switches. I power cycled both switches, and they came back up as follows:
Master: SYS light solid green. No other lights.
Slave: STBY, SYS, and ACTV lights all solid green. No other lights.
And I still can't reach the switches, or any device connected to the switches.
Can anyone help? Thanks!
Leo Laohoo
Two options:
Option 1:
conf t
 software auto-upgrade enable
end
wr
Option 2:
In Enable Mode, enter the following command:
install autoupgrade
Thanks, but I can't reach either switch. I worked remotely and putty in. I imagine someone will have to go onsite and connect to the console port, but I'm hoping to avoid that. There are people on site who can power cycle the switch, or switches, and tell us the status of the LEDs but that's all.
Jens Albrecht
Level 3
Level 3
Looks like you broke the stack but without console access you don't know the exact condition right now.
Based on the fact that you work remote but have people on-site you can try the following:
  • Power down the slave and check whether you can connect to the master remotely
  • If not, power cycle the master while the slave is still down, then check connectivity to the master again
  • If you can still not connect remotely, you probably have to go on-site and use the console port
  • If you can connect to the master, use option 2 that @Leo Laohoo mentioned to upgrade the master
    Once the master is upgraded and back online, power on the slave and check whether it rejoins the stack
In case you have some kind of terminal server at your site you can also check whether you can use it to connect to the console port of your devices.
HTH!
pieterh
If there is still some network connection possible then As alternative to the terminal server mentioned by @Jens Albrecht  you can remote desktop into a PC with serial connection to the console
