10-16-2014 07:11 AM - edited 03-07-2019 09:08 PM
Hey Guys,
I have a short question to the upgradepath of Cisco.
Device# sh version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.03.00SE
Would it be possible to upgrade directly to Version 3.3.xSE or is there an upgrade-path?
I did not see any path how to upgrade, but know that other companies have an upgrade-path.
Thank you for your time.
10-16-2014 10:10 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Usually you can install any IOS version supported by your hardware. I.e. you don't normally need to load intermediate IOS versions.
However, sometimes Cisco changes configuration statements between IOS versions. Jumping up a version or two is usually not a problem, but jumping many versions up, or even one version back, might cause some existing configuration statements to be unrecognized.
10-17-2014 03:58 AM
Hi Joseph,
thanks for your answer.
I saw, that the size of the switch is greater than 200 mb, so it would be better to use ftp, right?
A second question (because I am new on cisco catalyst series), where is the difference in the two software images:
CAT3850 UNIVERSAL W/O DTLS
and
CAT3850 UNIVERSAL
Many thanks
