10-07-2009 12:12 PM - edited 03-06-2019 08:02 AM
Hi all,
I need to upgrade my IOS from s72033-pk9sv-mz.122-17d.SXB11a to the newest IOS with security fixes. From what I found s72033-advipservicesk9_wan-mz.122-18.SXF17 seems to be the way to go but I would like to be sure. Should I expect to loose some features from this upgrade?
Thanks!
Solved! Go to Solution.
10-07-2009 12:54 PM
10-07-2009 12:33 PM
You will gain features in term of hardware and software support.
For the list please refer to the Release Notes:
HTH,
___
Edison.
10-07-2009 12:47 PM
Thanks a lot, so you confirm that in order to keep the same feature set from the old packaging (s72033-pk9sv-mz) to the new (s72033-advipservicesk9_wan-mz) that would be the way to go?
10-07-2009 12:54 PM
Yes
10-07-2009 01:01 PM
I believe that is the closest feature sets by comparing the name
ADV IP W/MPLS/IPV6/SSH/3DES + BGP
s72033-pk9sv-mz.122-17d.SXB11a.bin
Release Date: 16/Apr/2006
Size: 41144.47 KB (42131936 bytes)
Minimum Memory: DRAM:512 MB Flash:64 MB
ADVANCED IP SERVICES SSH
s72033-advipservicesk9_wan-mz.122-18.SXF17.bin
Release Date: 30/Sep/2009
Size: 79043.54 KB (80940580 bytes)
Minimum Memory: DRAM:512 MB Flash:128 MB
You can compare the feature set with
10-07-2009 01:06 PM
Jerry, that's the code he posted on his original message :)
10-07-2009 01:08 PM
Agree Edison.
