Upgrading Cisco 2800 to voice capabilities
feisalb
Hello All
I have a customer who has a Cisco 2821 router with software 2821/HSEC/K9 and they wish to upgrade to C2821-VSEC-SRST/K9.
From my understanding they want to use the same router but install an IOS with the capabilites it has at the moment but with voice.
So they currently have:
Cisco 2821 CISCO2821-HSEC/K9 which is Cisco 2821 Security Bundle with IOS Advanced IP Services, AIM-VPN/SSL-2, 64 MB Flash/256 MB DRAM, 10 User SSL License
and they want to have the equivalent of :
C2821-VSEC-SRST/K9 , 2821 VSEC Bundle with PVDM2-32, FL-SRST-48, Adv IP Serv, 128F/256D.
How do I go about pricing this up and what upgrade sku's will do this?
I am not to worried about the memory.
Is it just a simple ios upgrade as the srst licenses are on a trust basis?
Your help is much appreciated
Feisal
feisalb
Is it a matter of just buying the feature license FL-SRST-50 as ip advanced services should already have voice capabilities?
Feisal
Leo Laohoo
PVDM2-32
You need the voice module and the IOS feature set to run the module.
If you plan to terminate the phone lines to your router then you need an FXS and/or an FXO WIC card.
Not sure about the DRAM available.
The easiest way is to spec out a brand new voice bundle.  Less hassle.
