Upgrading IOS on 4500x Switches
c-davies
I need the crypto version of IOS for a VSS pair of 4500x-32 port switches.
I tried what I thought was the usual upgrade process.
tftp image to bootflash: and slavebootflash: and config to boot system flash blah.bin
wr mem
reloaded both switches.
on Bootup the cli simply says using 1st file on flash.
I followed the process which wanted to change the config-register to 0x2102 for some reason? and a redundancy peer reload, this simply put my swithes into rommon mode.
Whatever process I try the switches will not load the same version k9 crypto file, its simply ignored. Are we back to the old days of having to order the image on the bootflash?
Please help if anyone knows how to upgrade these switches, they are not production yet in pre-stagng so uptime is not important yet.
My current version is -
System image file is "bootflash:/cat4500e-universal.SPA.03.04.00.SG.151-2.SG.bin"
I want to load
cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin
Which exists on the bootflash and slavebootflash
Chris
17 Replies 17
Richard Burts
Can you post the output of the show command to display the boot variables and the output of show flash? Perhaps there is some syntax issue?
Also can you post all of the console output during an attempt to boot? Perhaps there is some issue in the boot process or with validity of the file in flash?
Rick
Rick
I am confused as to what the config-register should be, I can't find it documented.
I configured the boot string
Boot system flash:cat4500-universal.spa.03.04.00.sg.151-2.sg.bin
I reboot the switch and it goes into rommon mode.
It says invalid filename.... It must begin with a device name.
Please help.
It boots ok from Rommon if I manually type it.
Chris
I think the correct syntax is "boot system flash bootflash:xxx" and not "boot system flash:xxx"
so in your case it would be:
4500x(config)#boot system flash bootflash:cat4500-universal.spa.03.04.00.sg.151-2.sg.bin2.SG5.bin
other options are:
4500x(config)#no boot system ?
  flash  Boot from flash memory
  ftp    Boot from a server via ftp
  mop    Boot from a Decnet MOP server
  rcp    Boot from a server via rcp
  tftp   Boot from a tftp server
  <cr>
4500x)config)#boot system flash ?
  WORD  System image filename
  <cr>
Yes - just as I posted earlier in this thread - 2 years ago. :)
Cheers, a long document for a simple process, I just want to upgrade the damm things lol
Hi Chris,
Were you able to get this resolved? let me know if you still need assistance, I can help.
Luke
c-davies
Not resolved yet but I have a TAC case open.
Sent from Cisco Technical Support Android App
Hello guys,
Just upgraded my cisco 4500x.
In fact the proccess is simple, you just have to upload the new IOS and then delete the old one from bootflash.
Then add the correct bootflash line in your configuration.
C.
I am having the same issue. What was the correct bootflash line? Was it boot system flash:imagename ? It will not let me specify bootflash:
BTW ISSU will not work when going from non K9 version to K9. It will fail.
Where is the current image located?  That's what you would use  if it's not in bootflash:  .  Cisco likes to change names and confuse people like bootflash, bootdisk,  etc...
boot system flash bootflash:cat4500e-universalk9.SPA.03.04.00.SG.151-2.SG.bin
That's what I used successfully on a production 4500X VSS cluster. I upgraded the units separately during staging prior to building them into a VSS.
Configuration register is 0x2102. That tells the switch rommon to boot the image specified in the startup configuration file.
c-davies
Hello, resolved.
You cant cant upgrade via the ISSU process when changing from no crypto to crypto image. SSH requires crypto. What you have to do is upgrade in the old style, reboot, the two boxes moan, you break VSS. Then upgrade the second box manually then bring the VSS up again.
VSS-ROUTER(config)#boot system flash bootflash:cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin
VSS-ROUTER(config)#do wr
Building configuration...
Compressed configuration from 22592 bytes to 9330 bytes[OK]
VSS-ROUTER(config)#do sh bootv
BOOT variable = bootflash:cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby BOOT variable = bootflash:cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin,1;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
VSS-ROUTER#redundancy reload peer
Reload peer [confirm]
VSS-ROUTER#
Preparing to reload peer
