Upgradingg
npatel0011
I Have a 3560 series switch 24 ports. I never updated the ios before.. if upgrading to the new version of the ios, will that affect anything... Should I upgrade it? what will be the benefits... thanks for the reply......
5 Replies 5
Reza Sharifi
If your switch is working fine and you don't any new features that come with newer IOS versions than really there is no need to upgrade.  You can also upgrade to a newer version, but you would need to keep an eye it just in case you encounter any issue.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Reza notes, if your switch is working fine and you don't need any newer IOS features, there's no need to upgrade, yet working fine might be qualified with at-the-moment.
Generally, to avoid tripping over known bugs, that have been corrected, you might consider upgrading to the latest image in your current software train.  For example, if you had 55SE3, you might want to move to 55SE9.  Usually, such an upgrade is fairly safe, but Cisco (as other vendors do too) occasionally introduces new bugs, even with just bug fix releases.
BTW, some bugs are security related, so even if everything is working fine, without an updated IOS, your device may be exposed to a known security flaw.  To fix some of these, you sometimes need to jump to a newer IOS version (which exposes you to bugs also introduced with the new features).
Another reason to upgrade to a newer IOS, sometimes Cisco makes internal improvements to how the device performs.  I.e. it just works a little better doing what it already does.
To recap, the biggest reasons to upgrade are to address known bugs, which are causing you issues, and/or use new features you really want to take advantage of.  Either of the prior reasons sort of forces you to upgrade.  However, even when you're not "forced" to upgrade, there still can be advantages to upgrading.  The latter, though, can be a difficult decision because any upgrade can introduce new problem issues.
PS:
BTW, the 55SE9 image is consider by many to be about the most solid 3750 (and 3560?) IOS version.
Moin Ilyas
Level 4
Level 4
What is the current IOS version you are using at the moment?
 C3560 Software (C3560-IPBASE-M), Version 12.2
Please refer to the following link under New Software Features being supported:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/release/notes/OL23054.html#pgfId-1047679
Hope that helps.
