Showing results forĀ
Search instead forĀ
Did you mean:Ā
Uplink Cisco 2960x with HP 2530 switch
marekp222
Guys,
I need help with connecting Cisco 2960x with HP 2530 switch. When I connect those two switches using crossover cable i get the following error message:
Jan  6 15:35:52.232: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk GigabitEthernet1/0/1 VLAN1.
Jan  6 15:35:52.232: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking GigabitEthernet1/0/1 on VLAN0001. Inconsistent port type.
Jan  6 15:35:53.015: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Jan  6 15:35:57.663: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Jan  6 15:36:06.730: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk GigabitEthernet1/0/1 VLAN1.
Jan  6 15:36:06.730: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking GigabitEthernet1/0/1 on VLAN0001. Inconsistent port type.
Even when I create a trunk on HP switch and channel-group on Cisco, I still get the same error messages.
Any idea? I highly appreciate your help,
Thanks you. Mark
9 Replies 9
casa_far
The error seems to be related to the spanning tree, maybe on cisco side you have the portfast enabled on port facing to hp and on the hp port you
have the stp enabled.
In such scenario hp is sending bpdu on a port where cisco is not expecting It.
The bpdu are the packets used by switches in order to make calculations in an stp domain.
My suggestion is to remove the portfast on cisco port "no spanning-tree portfast". After that when you connect the port on hp you will have to wait some seconds (30 sec +/- ) before the port goes in forwarding.
Actually there should be other tunings to do If It's still not working please post the configuration of cisco and hp.
You are absolutely right, when I disable spanning-tree on vlan 1, the connection between two switches is fine.
Q1. What is the proper way uplinking Cisco and HP switch? Is single crossover cable enough or LACP channel between Cisco and HP is required?
Here's the config from HP switch:
Running configuration:
hostname "hatdry-copyroom01"
no telnet-server
no web-management
web-management ssl
snmp-server community "public" unrestricted
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-52
   ip address 10.128.1.109 255.255.0.0
   exit
Here's the config from Cisco switch:
Building configuration...
switch 1 provision ws-c2960x-48ts-l
spanning-tree mode pvst
vlan internal allocation policy ascending
lldp run
interface FastEthernet0
 no ip address
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
 ip address 10.128.1.11 255.255.0.0
 no ip route-cache
ip default-gateway 10.128.1.1
no ip http server
ip http secure-server
snmp-server community ***** RO
line con 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
ntp server 10.118.3.20
end
Mark both work, single crossover or LACP. BUT in the network world I would always recommend using more than one uplink between switches. One single point of failure between you and several devices is really rolling the dice. Also it will provide more bandwidth (not sure how many host will be using the switch) for your end devices.
JDGranger, single crossover or patch and the following configuration on the Cisco switch would be enough to create a uplink between Cisco and HP switches, right?
interface GigabitEthernet1/0/25
 switchport mode trunk
Thanks for all your help
devils_advocate
Level 7
Level 7
Hi Mark
What does the config look like on the HP Side?
The word Trunk on HP is not the same as Cisco, Trunk on HP refers to PortChannel in the Cisco world.
On the HP side, you need to 'Untag' the Vlan which needs to be the Native Vlan (Vlan 1 usually) and Tag all other Vlans that you want to pass across the link.
The Cisco side is needs to be a trunk with 'switchport mode trunk' and assuming the native vlan has been left as the default (i.e vlan 1) then so do what I said on the HP side above and it should be ok.
Cheers
HP side is very simple as shown below:
no telnet-server
no web-management
web-management ssl
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-52
   exit
And I did what you have mentioned above on Cisco side as shown below:
Now, the interface is up and I can ping that Cisco switch:
Jan  6 16:46:10.125: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
Jan  6 16:46:12.135: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
Jan  6 16:46:41.146: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
In other locations, I'm using LACP channel between Cisco and HP switches with no issues and I don't understand why it would not work this time.
Here's what I have done in the past on cisco switch:
Conf t
Channel-group 1 mode active
description Channel/Trunk to HP switch
Here are steps for HP switch:
config t
trunk 1,2 trk1 lacp
I would like to configure these two switches in the same mode utilizing two ports in LACP.
Any idea what I'm missing or doing wrong?
On the Cisco side, I would always configure the ports to be a static trunk port (switchport mode trunk) as this is best practice.
Looking at your configuration, all your ports are untagged in Vlan 1 which means the HP has a 'Trunk' but its passing all its frames untagged across it as only one vlan exists and this is the native vlan anyway which is fine.
Your config above looks fine from the Cisco side, channel-group 1 mode active will tell the Cisco to actively try and negotiate LACP with the HP. The HP looks fine in regards to the LACP config but I believe you need to add this PortChannel interface as untagged to Vlan 1 so:
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-52, trk1
   exit
Similar to the Cisco, the HP sees 'trk1' as its portchannel interface and although this is only a virtual interface, you still need to add it to the Vlan configurations.
Hope this helps.
Finally I got it to work, the trunk/channel between HP and Cisco is up and running; however, I'm not sure why it does work in different location.
Location A:
Config from HP:
interface 49
   name "Trunk Trk1 to ga-swcomm01cisco"
   no lacp
exit
interface 50
   no lacp
exit
trunk 49-50 Trk1 LACP
ip default-gateway 10.118.1.1
vlan 1
   name "DEFAULT_VLAN"
   untagged 1-48,Trk1
   ip address 10.118.1.100 255.255.0.0
   exit
spanning-tree Trk1 priority 4
Config from Cisco:
interface Port-channel1
Location B:
I use the same configuration as in location A and it did not work with the following results:
Thanks to you (devils_advocate) I did change my configs on Cisco to reflect your sugegstions about configuring ports to be static trunk port and it does work. Please, look below and let me know if I follow industry standards and hopefully not causing any problems down the road.
Config from HP:
trunk 1-2 trk1 lacp
no telnet-server
no web-management
web-management ssl
interface 1
   name "Trunk Trk1 to core switch"
   exit
interface 2
   exit
vlan 1
   name "DEFAULT_VLAN"
   untagged 3-52,Trk1
   exit
Config from Cisco:
 description "Channel to HP switch"
 no ip address
 channel-protocol lacp
Per your recommendation each interface that belongs to that port-channel is set to static trunk port (switchport mode trunk). Is this supposed to be set on each interface or on channel group? I did on both, channel group and each individual interface.
I'm very curious why location A works with no issues but location B did require additional configuration. Do you think different firmware/IOS would cause this?
Thank you for all your help,
Mark
Hi Mark, Can you help me with some similari ?   I have a aruba switch 2930f and cisco switch, I need conect with fiber but a not sure that configuration do it .
