uplink to 6500 1000BaseX from3750 with 10GB GBIC module
rohit.kulkarni
I am having two 3750 in stack and I am thinking toreplace a GBIC from1 gb to 10 gb which is connecting to 6500 switch.  I am not sure if Core will support this connectivity?
Core:
   1    2     1000BaseX Supervisor      WS-X6K-SUP2-2GE     yes standby
15  1    1     Multilayer Switch Feature WS-F6K-MSFC2        no  ok
2   2    2     1000BaseX Supervisor      WS-X6K-S2-MSFC2     yes ok
16  2    1     Multilayer Switch Feature WS-F6K-MSFC2        no  ok
3   3    16    1000BaseX Ethernet        WS-X6416-GBIC       no  ok
8   8    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      no  ok
9   9    48    10/100BaseTX Ethernet     WS-X6348-RJ-45      no  ok
3750;
"GigabitEthernet1/0/49", DESCR: "1000BaseSX SFP
Thx
InayathUlla Sharieff
Hi Rohit,
As per the datasheet for 10Gig cards for 6500, they are supported only on Supervisor Engine 720
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet09186a00801dce34.html
Inayath
*Plz dont forget to rate usefull posts.
8 Replies 8
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
It doesn't appear you have any 10g ports on your 6500.
Since you're using sup2s, I'm unsure they support 10g line cards.
Thank You.
I was planning to use 10 gb module instead of 1gb with my new 3750 switch.
Hi Rohit,
Inayath
Thank You.
I am connecting 3750 stack to 6500 and I have 1gb module that I was planning to replace it with 10gb. will it work?
InayathUlla Sharieff wrote:
Hi Rohit,
Inayath
Adding to my thread, I am planning to use 10gn module on 3750 and not on 6500. I am leaving 6500 as it is and planning to uplink 3750 with 10gb module to 6500. Hope this will clear my query.
That will not work.  You can not connect a 10Gig port to a 1Gig port.  Both sides have to have the same speed
If you want to replace your 3750 module and use a 10Gig, then you need a 10Gig module on the 6500 side too.
BTW, you could connect the 10Gig 3750 to the 6500 if you had a Sup with 10Gig ports on it.  Yours does not have any.
Hi Rohit,
Yes we got that, You will use 10Gig on 3750 and 1 gig on 6500.
3750---10Gig---------------1Gig 6500.
This way it doesnt work. Both sides need to be on same speed and duplex. The problem you have encoutered is that your Core Switch 6500 doesnt have 10 GB support either on Sup module nor it supports 10 Gig line cards :-(
Hence conclusion you cannot use this setup..
Inayath
