Uplinks redundncy between VSS core switch and 4500 Switch with 2 Supe.
eng.malak
Hello
I have a design like below
Cre Layer
  • 2x6500 in VSS state
Edge Layer
  • 4500 edge switch that includes two WS-X45-SUP6L-E/2 ,  one sup in active state and the other in standby state
  • every sup uses 10G uplink to the core switch
the question isregarding the edge switch
  • if the uplink on the active Sup came down can the active Sup use the other uplink connected to the standby Sup , and if yes what can make it comes true?
  • can both Uplinks on both Sups particpate in Ether channel ?
Thank you
Reza Sharifi
Yes, both links from both Sups can participate in Ether channel .  On the 4500 make sure that both Sups are in SSO mode and then build a Portchannel and put one 10Gig link from each Sup in that Portchannel.
Reza
