VSS Question?
csc010627097
Community Member
HI everybody,
I have  two 6506-E and I would like to implement VSS.
1) Do I must  to have 10GbE interface to implement it?
2) I have some servers connected only to one of my 6506-E. Should them be connected to both of my 6506-E if I implement VSS?
THanks for your replay
regards
Leo
Reza Sharifi
Hi Leo,
Yes, the VSL links between the 2 switches need to be 10Gig links
If your servers have 2 NICs, yes, you should connect one link to each 6506-E using Portchannel.  This way you have switch and NIC redundancy.
Reza
