upoe and cable distance
bluesea2010
Level 5
Level 5
Upoe ports  has any cable limitation . I have cat 6a and 7
There´s no limitation in terms of category. UPOE will send 90W instead 30W but it it supported in any category. They actually stablish a minimum category which is Cat5e but we know that lower then Cat5e is not recommended any way.
Refers to the link for detailed information and examples.
https://www.networkacademy.io/ccna/ethernet/power-over-ethernet
Leo Laohoo
Same as before:  <100 metre distance.
