uPRF Question!
abbas.ali
Level 3
Level 3
I have been recommended to enable  Unicast Reverse Path Forwarding (uPRF) and wanted to know wheter it  should be enabled on external interface or internal interface on the  following devices:
ASA Firewall
Internet Border Router
MPLS Router, and
Catalyst 6500 switches.
Reza Sharifi
According to this doc, the command is enabled by default an all devices running IOS 12.2 and later
have a look:
http://www.cisco.com/web/about/security/intelligence/unicast-rpf.html
